Source Builder failure on Ubuntu.
    Ritesh Harjani
    ritesh.harjani at gmail.com
    Sun Sep  1 17:10:46 UTC 2013
Hi Karel,
I am not sure, what error you got while following Alan's blog as you didnt
mention the build failure logs.
Could you please tell the host machine configuration. Is it 64 or 32bit??
Also, the error log.
Thanks
Ritesh
On Sun, Sep 1, 2013 at 10:17 PM, Karel Gardas <karel.gardas at centrum.cz>wrote:
> Hello,
> I'm trying to use source builder on ubuntu 12.04 AMD64, but the build
> process fails with:
> prep: arm-rtems4.11-kernel-4.11-1: %setup -q -c -n
> arm-rtems4.11-kernel-4.11-1-4.**11
> making dir: /home/karel/development/rtems/**rtems-source-builder/rtems/**
> sources
> download: http://ftp.rtems.org/ftp/pub/**rtems/4.11/rtems-4.11.tar.bz2<http://ftp.rtems.org/ftp/pub/rtems/4.11/rtems-4.11.tar.bz2>
> git://git.rtems.org/rtems.git?**reset=hard?pull<http://git.rtems.org/rtems.git?reset=hard?pull>-> sources/rtems.git?reset=hard?
> **pull
> git://git.rtems.org/rtems.git?**reset=hard?pull<http://git.rtems.org/rtems.git?reset=hard?pull>:
> error: <urlopen error no host given>
> Build Set: Time 0:24:09.458279
> error: downloading http://ftp.rtems.org/ftp/pub/**
> all paths have failed, giving up
> this happen twice from two attempts so I guess this is not temporal ftp
> server problem but probably more solid issue.
> To invoke source-builder I've followed information given by Alan on his
> blog here:
> http://alanstechnotes.**blogspot.cz/2013/03/setting-**
> up-rtems-development.html<http://alanstechnotes.blogspot.cz/2013/03/setting-up-rtems-development.html>
> -- the step:
> 4. Build and install the toolchain
> $ cd $HOME/development/rtems/rtems-**source-builder/rtems
> $ ../source-builder/sb-set-**builder \
>          --log=build-log.txt \
>          --prefix=$HOME/development/**rtems/compiler/4.11 \
>           4.11/rtems-arm
> is what fails here.
> My question is: is there something I've done wrong or is it known issue in
> source-builder or on ftp server?
> Thanks!
> Karel
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130901/f0b85d26/attachment-0001.html>
