Source Builder failure on Ubuntu.
Mon Sep 2 02:24:54 UTC 2013
Rui Zhengxin wrote:
> This rtems source tar ball URL is not exist.
Correct. We have not released RTEMS 4.11.
> But why the git pull command returns fail too?
I suspect the arguments to it are wrong or confused because of a bug.
The bug does not handle nested "if's" cleanly and I added an outer 'if'
to support '--without-rtems' and that exposed the bug. I have a patch I
am testing at the moment however it takes a while to run a test to build
all tools.
> I don't need the rtems kernel building, so I avoid this issue:)
Great. Building with RTEMS is the default for releases where you will
want the version of RTEMS and a tarball will exist. Maybe it should be
off for development versions.
