RTEMS C++ global constructor for Sparc
Tue Apr 1 15:21:49 UTC 2014
I am confused. Did you build RTEMS with --enable-cxx?
Did you make the linkcmds changes discussed?
In RTEMS, the C++ global constructors are called by the first thread
that executes. Before that, almost anything a constructor is allowed
to do that is not pure computation or memory initialization would
not be valid because the OS and tasking are not running.
There is a call in _Thread_Handler to the constructor execution method.
The name varies by target so it is a macro named INIT. A few lines of code
later the user init task is invoked.
Let's keep this on rtems-users so others benefit from the discussion.
--joel
On 3/27/2014 9:00 PM, Thomas (Gmail) wrote:
> On referencing, I misunderstood that _init() call not C++ constructor
> function because there is not C++ constructor function in crti.o.
> Today, after I make object dump file about elf file(cxx_throw.exe), I
> checked that below objdump information. It included ++ constructor as
> like below;
> 02066130 <_init>:
>  2066130:9d e3 bf a0 save  %sp, -96, %sp
>  2066134:7f fe 6c 60 call  20012b4 <frame_dummy>
>  2066138:01 00 00 00 nop
>  206613c:7f ff e8 99 call  20603a0 <__do_global_ctors_aux>
>  2066140:01 00 00 00 nop
>  2066144:81 e8 00 00 restore
>  2066148:81 c3 e0 08 retl
>  206614c:01 00 00 00 nop
> I am sorry for my misunderstanding.
> Best Regards
> 2014-03-28 10:19 GMT+09:00 Thomas (Gmail) <thomas73.kim at gmail.com
> <mailto:thomas73.kim at gmail.com>>:
>     Please check that my modification is correct.
>     I modified linkcmds.base according to your comment.
>     (Before)
>         KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>         KEEP (*(SORT(.ctors.*)))
>         KEEP (*(.ctors))
>         KEEP (*crtbegin.o(.dtors))
>         KEEP (*crtbegin?.o(.dtors))
>         KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>         KEEP (*(SORT(.dtors.*)))
>         KEEP (*(.dtors))
>     (After)
>         KEEP (*(.ctors*))
>         KEEP (*(.dtors*))
>     Also, I compared map file.
>     (Before)
>      *(.ctors)
>      .ctors         0x0206040c        0x4
>     /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtend.o
>      *crtbegin.o(.dtors)
>      .dtors         0x02060410        0x4
>     /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtbegin.o
>      *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
>      *(SORT(.dtors.*))
>      *(.dtors)
>     (After)
>     *(.ctors*)
>      *crtbegin.o(.dtors)
>      *(SORT(.dtors.*))
>      *(.dtors*)
>     Best Regards
>     2014-03-28 2:00 GMT+09:00 Joel Sherrill <joel.sherrill at oarcorp.com
>     <mailto:joel.sherrill at oarcorp.com>>:
>         I am out of the country and teaching this week. Trying adding an
>         "*" after ctors and before the parentheses. Ditto for dtors so
>         it wild
>         card matches.
>         Look at how .text has a * on it
>         On 3/27/2014 10:25 AM, Thomas (Gmail) wrote:
>>         I am tring to compare linkcmd.base and toolchain's
>>         elf32_sparc.x.
>>         But, I am difficult to modify linkcmd.base for this.
>>         Please could you send to me the revised linkcmd.base file ?
>>         2014-03-27 18:18 GMT+09:00 Joel Sherrill
>>         <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>:
>>             libgcc2 is already in the toolset. This almost 100%
>>             certainly is a small
>>             bug in
>>             c/src/lib/libbsp/sparc/shared/startup/linkcmds.base.  Look
>>             at how the .ctors are referenced in the files
>>             elf32_sparc.x* installed
>>             as part of the toolset in
>>             $prefix/sparc-rtems4.11/lib/ldscripts. They
>>             have "." and a "*" in the KEEP lines. I don't think we
>>             have that.
>>             The problem was almost certainly introduced with function
>>             sections
>>             being used and I missed a wildcard on the ctor/dtor lines.
>>             On 3/27/2014 3:04 AM, Thomas (Gmail) wrote:
>>>             On referencing, I am a beginner regarding this.
>>>             As I know from googling information, name of the section
>>>             for constructor is in .ctors section in linkcmds.base.
>>>             below reference code is from gcc-4.8.2/libgcc/libgcc2.c
>>>             because __do_global_ctors() function is in libgcc2.c, I
>>>             tried to add libgcc.a in rtems building environment.
>>>             but, I didn't complete.
>>>             < libgcc2.c >
>>>             /* Run all the global destructors on exit from the
>>>             program.  */
>>>             void
>>>             __do_global_ctors (void)
>>>             #ifdef EH_FRAME_SECTION_NAME
>>>                 static struct object object;
>>>                 __register_frame_info (__EH_FRAME_BEGIN__, &object);
>>>             #endif
>>>               DO_GLOBAL_CTORS_BODY;
>>>               atexit (__do_global_dtors);
>>>             < gbl-ctors.h>
>>>             /* Some systems use a different strategy for finding the ctors.
>>>                For example, svr3.  */
>>>             #ifndef DO_GLOBAL_CTORS_BODY
>>>             #define DO_GLOBAL_CTORS_BODY						\
>>>             do {									\
>>>               unsigned long nptrs = (unsigned long) __CTOR_LIST__[0];		\
>>>               unsigned i;								\
>>>               if (nptrs == (unsigned long)-1)				        \
>>>                 for (nptrs = 0; __CTOR_LIST__[nptrs + 1] != 0; nptrs++);		\
>>>               for (i = nptrs; i >= 1; i--)						\
>>>                 __CTOR_LIST__[i] ();						\
>>>             } while (0)
>>>             #endif
>>>             2014-03-27 16:33 GMT+09:00 Joel Sherrill
>>>                 On 3/27/2014 2:30 AM, Sebastian Huber wrote:
>>>                 > On 2014-03-27 06:28, Thomas (Gmail) wrote:
>>>                 >> I am tring to add libgcc.a in linking process for
>>>                 calling __do_global_ctors().
>>>                 > If you have to do this by hand, then your build
>>>                 process is broken.  How did you
>>>                 > get the RTEMS tool chain?  Which RTEMS version do
>>>                 you use?
>>>                 >> Please could you let me know how to add libgcc.a
>>>                 in RTEMS building environment ?
>>>                 >> If this approach is not correct, please let me
>>>                 know correct how-to-do for C++
>>>                 >> global constructor for Sparc.
>>>                 > It should work out of the box.
>>>                 Just out of curiosity what is the name of the
>>>                 section that the
>>>                 constructor is in?
>>>                 When I turned on function sections, it may now be in
>>>                 .initXXX instead of
>>>                 just .init.
>>>                 This would mean that an asterisk is needed in the
>>>                 linkcmds.base for init
>>>                 and fini
>>>                 to pick up all the methods. There is a KEEP() around
>>>                 them which I
>>>                 thought might
>>>                 be the issue.
>>>                 Joel Sherrill, Ph.D.             Director of
>>>                 Research & Development
>>>                 <mailto:joel.sherrill at OARcorp.com>        On-Line
>>>                 Applications Research
>>>                 Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>                 Support Available                (256) 722-9985
>>             Joel Sherrill, Ph.D.             Director of Research & Development
>>             joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>        On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20140401/30ff9618/attachment.html>
