Window Tools was Re: Latest RTEMS without posix support
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 2 16:26:32 UTC 2014
What does mips-rtems4.11-gcc --version say? My sparc toolset says
$ sparc-rtems4.11-gcc --version
sparc-rtems4.11-gcc (GCC) 4.8.2 20131016 (RTEMS
4.11-RSB-dac3a03c03c659f23bf199b65ff126e1aad1da5c-modified-1,gcc-4.8.2/newlib-2.1.0)
I am suspicious the windows tools are out of date.
On 4/2/2014 10:12 AM, Serg Kruglov wrote:
> *From:* Joel Sherrill <mailto:joel.sherrill at oarcorp.com>
> *Sent:* Wednesday, April 02, 2014 6:46 PM
> *To:* Serg Kruglov <mailto:skruglov at nm.ru> ; rtems-users at rtems.org
> <mailto:rtems-users at rtems.org>
> *Subject:* Re: Latest RTEMS without posix support
> I configure with:
> /opt/rtems-4.11/rtems-master/configure --target=mips-rtems4.11
> --enable-rtemsbsp="genmongoose" --disable-networking --disable-itron
> --disable-cxx --enable-rtems-debug=yes --disable-multiprocessing
> --enable-maintainer-mode –disable-posix --enable-test=yes
> gcc 4.8.2 with mingw64 directory , newlib 2.0.0 with mips patches
> (signal patch not implemented)
> Also with –enable-posix testsuites build, only samples directory
> Печальная рожица
> If run fileio.exe test and select “run shell” :
> rtems_libio_set_private_env(): (status: RTEMS_TOO_MANY)
URL: <http://lists.rtems.org/pipermail/users/attachments/20140402/3ba98df2/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20140402/3ba98df2/attachment.png>
