Window Tools was Re: Latest RTEMS without posix support
Thu Apr 3 10:54:42 UTC 2014
On 2014-04-03 12:23, Serg Kruglov wrote:
> All, question closed.
> I get latest newlib-2.1.0.tar.gz,
> rtems-4.11-mips-rtems4.11-gcc-4.8.2-4-src.tar.xz, pathes with rtems-tools.
> Apply patches similarly source-builder, build toolchain.
> All OK, but two features:
> 1. I configure with –enable-tests=yes , but building only testsuites\samples
Maybe we should fix this in the configure.ac file, --enable-tests will build
all tests.
> 2. fileio.exe after run shell say “rtems_libio_set_private_env(): (status:
> RTEMS_TOO_MANY)”
>      its corrected if I manually build fileio with non zeroed
> CONFIGURE_MAXIMUM_POSIX_KEYS and CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
Ok, I fixed this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
