Eclipse plugin and project Hello
Mohammed Khoory
mkhoory at eiast.ae
Mon Apr 21 00:25:00 UTC 2014
I encountered this. I'm not sure why it happens, but I worked around it by
switching to Eclipse Helios. That is a very old version however.
It'll be great if someone can at least update the Eclipse plugins to get
them to work with the newer versions.
From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
On Behalf Of Mr. Andrei Chichak
Sent: Saturday, April 19, 2014 2:13 AM
To: RTEMS List
Subject: Re: Eclipse plugin and project Hello
Also happens with MacOS 10.8.5, Eclipse Kepler, Eclipse plugin
1.4.0.200911301509 (yay for eclipse consistency)
A
On 2014-April-18, at 4:56 AM, Serg Kruglov <skruglov at nm.ru> wrote:
I select New Project->C Project->Executable->RTEMS Hello-World Project.
Select toolchain, press Next, confirm source directory and press Next.
List available configuration is empty <wlEmoticon-sadsmile[1].png>
Project type: Executable
Toolchain: RTEMS toolchain
Configuration:
Also source files not founds.
Windows 7, Eclipse Kepler, Msys+Mingw, Eclipse plugin 1.4
RTEMS 4.11 installed and if I create new project without template al OK
URL: <http://lists.rtems.org/pipermail/users/attachments/20140421/c64c117e/attachment.html>
