AW: POSIX scheduling and priority question
Tue Apr 22 14:41:31 UTC 2014
On 4/22/2014 9:39 AM, Gempeler Stefan wrote:
> Hi Sebastian, thanks for your fast reply. Using PTHREAD_EXPLICIT_SCHED seems to solve the problem.
I was writing a reply when Sebastian's showed up. Glad it was right. :)
As a final throw in, passing NULL as the attributes to pthread_create()
uses the implementation's default attribute set. POSIX does not specify
what that is. So when you use NULL there, all bets are off for portable
behavior.
If you don't mind, could you clean up the entire example and provide
a README? If you are willing and make the code BSD or "as is" type
license, it would be good to put in examples-v2/posix.
> For the sake of completeness
> 	printk( "\n\n========= STARTING ============  %s, %s\n", __DATE__, __TIME__);
> 	// start the waiting task, highest priority
> 	test_param.sched_priority = sched_get_priority_max( SCHEDULER_POLICY );
> 	pthread_attr_setschedparam( &test_attr, &test_param );
> 	pthread_attr_setinheritsched( &test_attr, PTHREAD_EXPLICIT_SCHED );
> 	pthread_create( &thread_wait,	&test_attr,	test_wait_thread,	0 );
> 	// start the full running task, lowest priority
> 	test_param.sched_priority = sched_get_priority_min( SCHEDULER_POLICY );
> 	pthread_create( &thread_full,	&test_attr,	test_full_thread,	0 );
> Kind regards
> Stefan
> -----Ursprüngliche Nachricht-----
> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Gesendet: Dienstag, 22. April 2014 15:33
> An: Gempeler Stefan
> Cc: rtems-users at rtems.org
> Betreff: Re: POSIX scheduling and priority question
> On 2014-04-22 14:53, Gempeler Stefan wrote:
>> void *POSIX_Init( void *argument )
>> #define SCHEDULER_POLICY                     (SCHED_RR)
>>                  pthread_t           thread_full;
>>                  pthread_t           thread_wait;
>>                  pthread_attr_t                test_attr;
>>                  struct sched_param       test_param;
>>                  assert( sem_init( &test_semaphore, 0, 0 )==0 );
> This is very dangerous since #define NDEBUG will wipe out this function call.
>>                  // get default attributes
>>                  pthread_attr_init( &test_attr );
>>                  // store parameters
>>                  pthread_attr_getschedparam( &test_attr, &test_param
>>                  // set policy
>>                  pthread_attr_setschedpolicy( &test_attr,
>> SCHEDULER_POLICY );
>>                  printk( "\n\n========= STARTING ============  \n" );
>> SCHEDULER_POLICY );
>>                  assert( pthread_attr_setschedparam( &test_attr,
>> &test_param
>> )==0 );
> See also PTHREAD_INHERIT_SCHED vs. PTHREAD_EXPLICIT_SCHED.
> rtems-users mailing list
