Eclipse plugin and project Hello
Thu Apr 24 11:14:20 UTC 2014
On 2014-04-18 12:56, Serg Kruglov wrote:
> I select New Project->C Project->Executable->RTEMS Hello-World Project. Select
> toolchain, press Next, confirm source directory and press Next.
> List available configuration is empty Печальная рожица
> Project type: Executable
> Toolchain: RTEMS toolchain
> Configuration:
> Also source files not founds.
> Windows 7, Eclipse Kepler, Msys+Mingw, Eclipse plugin 1.4
> RTEMS 4.11 installed and if I create new project without template al OK
The template projects never worked as far as I remember.  The source code for
the plug-in is here:
http://git.rtems.org/rtems-eclipse-plug-in/
So if someone has time to fix this, patches are welcome.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
