RTEMS C++ global constructor for Sparc
Daniel Hellstrom
daniel at gaisler.com
Tue Apr 1 20:09:32 UTC 2014
Hi,
The SPARC v7/v8 traps ends at 255, I dont have RTEMS code in front of me, perhaps there is a mask of 0x100 added to the trap number to indicate something.
Daniel
On 1 April 2014 17:44:38 CEST, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>OK.. replying to self..
>I made some changes locally and now have the examples-v2 sample
>cxx_throw nearly running. I am down to the spurious exception handler
>getting invoked on sis for exception 263 which I don't know what that
>is. [1]
>Does this run in gdb or exception mean anything to anyone?
>(gdb) r
>Starting program:
>/home/joel/rtems-4.11-work/examples-v2/cxx/cxx_throw/o-optimize/cxx_throw.exe
>Hey I'm in base class constructor number 1 for 0x2068384.
>Hey I'm in base class constructor number 2 for 0x206837c.
>Hey I'm in derived class constructor number 3 for 0x206837c.
>*** CONSTRUCTOR/DESTRUCTOR TEST ***
>Hey I'm in base class constructor number 4 for 0x20730f0.
>Hey I'm in base class constructor number 5 for 0x20730f8.
>Hey I'm in base class constructor number 6 for 0x2073100.
>Hey I'm in base class constructor number 7 for 0x2073108.
>Hey I'm in derived class constructor number 8 for 0x2073108.
>Testing a C++ I/O stream
>before try block
>Breakpoint 1, _Terminate (
> the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>is_internal=is_internal at entry=false,
>the_error=the_error at entry=34011320)
> at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:36
>36 {
>(gdb) bt
>#0 _Terminate
>(the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>#1 0x0203c454 in rtems_fatal (
> source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
> error=error at entry=34011320)
> at ../../../../../../rtems/c/src/../../cpukit/sapi/src/fatal2.c:34
>#2 0x02035f48 in bsp_spurious_handler (trap=263, isf=0x20721d8)
> at
>../../../../../../../../rtems/c/src/lib/libbsp/sparc/erc32/startup/spurious.c:131
>#3 0x0205fda4 in dont_fix_pil2 ()
> at
>../../../../../../../../rtems/c/src/lib/libbsp/sparc/erc32/../../sparc/shared/irq_asm.S:476
>#4 0x0205fda4 in dont_fix_pil2 ()
> at
>Backtrace stopped: previous frame identical to this frame (corrupt
>stack?)
>(gdb)
>#0 _Terminate
> at
> at
> at
>stack?)
>(gdb)
>[1] I am not feeling 100% well and am at home today. So don't have
>access to everything not inclination to hunt.
>On 4/1/2014 10:21 AM, Joel Sherrill wrote:
>> I am confused. Did you build RTEMS with --enable-cxx?
>> Did you make the linkcmds changes discussed?
>> In RTEMS, the C++ global constructors are called by the first thread
>> that executes. Before that, almost anything a constructor is allowed
>> to do that is not pure computation or memory initialization would
>> not be valid because the OS and tasking are not running.
>> There is a call in _Thread_Handler to the constructor execution
>method.
>> The name varies by target so it is a macro named INIT. A few lines of
>code
>> later the user init task is invoked.
>> Let's keep this on rtems-users so others benefit from the discussion.
>> --joel
>> On 3/27/2014 9:00 PM, Thomas (Gmail) wrote:
>>> On referencing, I misunderstood that _init() call not C++
>constructor
>>> function because there is not C++ constructor function in crti.o.
>>> Today, after I make object dump file about elf file(cxx_throw.exe),
>I
>>> checked that below objdump information. It included ++ constructor
>as
>>> like below;
>>> 02066130 <_init>:
>>> 2066130:9d e3 bf a0 save %sp, -96, %sp
>>> 2066134:7f fe 6c 60 call 20012b4 <frame_dummy>
>>> 2066138:01 00 00 00 nop
>>> 206613c:7f ff e8 99 call 20603a0 <__do_global_ctors_aux>
>>> 2066140:01 00 00 00 nop
>>> 2066144:81 e8 00 00 restore
>>> 2066148:81 c3 e0 08 retl
>>> 206614c:01 00 00 00 nop
>>> I am sorry for my misunderstanding.
>>> Best Regards
>>> 2014-03-28 10:19 GMT+09:00 Thomas (Gmail) <thomas73.kim at gmail.com
>>> <mailto:thomas73.kim at gmail.com>>:
>>> Please check that my modification is correct.
>>> I modified linkcmds.base according to your comment.
>>> (Before)
>>> KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>>> KEEP (*(SORT(.ctors.*)))
>>> KEEP (*(.ctors))
>>> KEEP (*crtbegin.o(.dtors))
>>> KEEP (*crtbegin?.o(.dtors))
>>> KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>>> KEEP (*(SORT(.dtors.*)))
>>> KEEP (*(.dtors))
>>> (After)
>>> KEEP (*(.ctors*))
>>> KEEP (*(.dtors*))
>>> Also, I compared map file.
>>> (Before)
>>> *(.ctors)
>>> .ctors 0x0206040c 0x4
>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtend.o
>>> *crtbegin.o(.dtors)
>>> .dtors 0x02060410 0x4
>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtbegin.o
>>> *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
>>> *(SORT(.dtors.*))
>>> *(.dtors)
>>> (After)
>>> *(.ctors*)
>>> *crtbegin.o(.dtors)
>>> *(SORT(.dtors.*))
>>> *(.dtors*)
>>> Best Regards
>>> 2014-03-28 2:00 GMT+09:00 Joel Sherrill
>>> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>:
>>> I am out of the country and teaching this week. Trying
>adding an
>>> "*" after ctors and before the parentheses. Ditto for dtors
>>> so it wild
>>> card matches.
>>> Look at how .text has a * on it
>>> On 3/27/2014 10:25 AM, Thomas (Gmail) wrote:
>>>> I am tring to compare linkcmd.base and toolchain's
>>>> elf32_sparc.x.
>>>> But, I am difficult to modify linkcmd.base for this.
>>>> Please could you send to me the revised linkcmd.base file ?
>>>> 2014-03-27 18:18 GMT+09:00 Joel Sherrill
>>>> libgcc2 is already in the toolset. This almost 100%
>>>> certainly is a small
>>>> bug in
>>>> c/src/lib/libbsp/sparc/shared/startup/linkcmds.base.
>Look
>>>> at how the .ctors are referenced in the files
>>>> elf32_sparc.x* installed
>>>> as part of the toolset in
>>>> $prefix/sparc-rtems4.11/lib/ldscripts. They
>>>> have "." and a "*" in the KEEP lines. I don't think we
>>>> have that.
>>>> The problem was almost certainly introduced with
>>>> function sections
>>>> being used and I missed a wildcard on the ctor/dtor
>lines.
>>>> On 3/27/2014 3:04 AM, Thomas (Gmail) wrote:
>>>>> On referencing, I am a beginner regarding this.
>>>>> As I know from googling information, name of the
>>>>> section for constructor is in .ctors section in
>>>>> linkcmds.base.
>>>>> below reference code is from
>gcc-4.8.2/libgcc/libgcc2.c
>>>>> because __do_global_ctors() function is in libgcc2.c,
>I
>>>>> tried to add libgcc.a in rtems building environment.
>>>>> but, I didn't complete.
>>>>> < libgcc2.c >
>>>>> /* Run all the global destructors on exit from the
>>>>> program. */
>>>>> void
>>>>> __do_global_ctors (void)
>>>>> #ifdef EH_FRAME_SECTION_NAME
>>>>> static struct object object;
>>>>> __register_frame_info (__EH_FRAME_BEGIN__,
>&object);
>>>>> #endif
>>>>> DO_GLOBAL_CTORS_BODY;
>>>>> atexit (__do_global_dtors);
>>>>> < gbl-ctors.h>
>>>>> /* Some systems use a different strategy for finding
>the ctors.
>>>>> For example, svr3. */
>>>>> #ifndef DO_GLOBAL_CTORS_BODY
>>>>> #define DO_GLOBAL_CTORS_BODY \
>>>>> do { \
>>>>> unsigned long nptrs = (unsigned long)
>__CTOR_LIST__[0]; \
>>>>> unsigned i; \
>>>>> if (nptrs == (unsigned long)-1) \
>>>>> for (nptrs = 0; __CTOR_LIST__[nptrs + 1] != 0;
>nptrs++); \
>>>>> for (i = nptrs; i >= 1; i--) \
>>>>> __CTOR_LIST__[i] (); \
>>>>> } while (0)
>>>>> #endif
>>>>> 2014-03-27 16:33 GMT+09:00 Joel Sherrill
>>>>> On 3/27/2014 2:30 AM, Sebastian Huber wrote:
>>>>> > On 2014-03-27 06:28, Thomas (Gmail) wrote:
>>>>> >> I am tring to add libgcc.a in linking process
>>>>> for calling __do_global_ctors().
>>>>> > If you have to do this by hand, then your build
>>>>> process is broken. How did you
>>>>> > get the RTEMS tool chain? Which RTEMS version
>do
>>>>> you use?
>>>>> >> Please could you let me know how to add
>libgcc.a
>>>>> in RTEMS building environment ?
>>>>> >> If this approach is not correct, please let me
>>>>> know correct how-to-do for C++
>>>>> >> global constructor for Sparc.
>>>>> > It should work out of the box.
>>>>> Just out of curiosity what is the name of the
>>>>> section that the
>>>>> constructor is in?
>>>>> When I turned on function sections, it may now be
>>>>> in .initXXX instead of
>>>>> just .init.
>>>>> This would mean that an asterisk is needed in the
>>>>> linkcmds.base for init
>>>>> and fini
>>>>> to pick up all the methods. There is a KEEP()
>>>>> around them which I
>>>>> thought might
>>>>> be the issue.
>>>>> Joel Sherrill, Ph.D. Director of
>>>>> Research & Development
>>>>> joel.sherrill at OARcorp.com
>>>>> <mailto:joel.sherrill at OARcorp.com> On-Line
>>>>> Applications Research
>>>>> Ask me about RTEMS: a free RTOS Huntsville AL
>35805
>>>>> Support Available (256) 722-9985
>>>> Joel Sherrill, Ph.D. Director of Research &
>Development
><mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Development
>>> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140401/64777b5c/attachment-0001.html>
