RTEMS C++ global constructor for Sparc
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 1 21:19:14 UTC 2014
On 4/1/2014 4:10 PM, Cláudio Silva wrote:
> If you are receiving trap 263 it should mean that you are receiving
> trap 7 when subtracted with the synchronous bit. Trap 7 is memory
> address not aligned in sis?
It is and all SPARC BSPs use the same linkcmds.
This may be dereferencing a special section which is not aligned
enough. C++ has
a number of them. The question is:
What does the method classify_object_over_fdes() really do?
Once we know the section(s) it uses, aligning it is easy.
--joel
> On Tue, Apr 1, 2014 at 9:36 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> On 4/1/2014 3:09 PM, Daniel Hellstrom wrote:
>> Hi,
>> The SPARC v7/v8 traps ends at 255, I dont have RTEMS code in front of me,
>> perhaps there is a mask of 0x100 added to the trap number to indicate
>> something.
>> OK. The 0x80 indicates synchronous trap:
>> * This macro indicates that @a _trap as a synchronous trap.
>> #define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 256 )
>> How about 137 or 0x87 which makes it a type of trap?
>> It is happening in classify_object_over_fdes if that helps.
>> --joel
>> Daniel
>> On 1 April 2014 17:44:38 CEST, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> OK.. replying to self..
>>> I made some changes locally and now have the examples-v2 sample
>>> cxx_throw nearly running. I am down to the spurious exception handler
>>> getting invoked on sis for exception 263 which I don't know what that
>>> is. [1]
>>> Does this run in gdb or exception mean anything to anyone?
>>> (gdb) r
>>> Starting program:
>>> /home/joel/rtems-4.11-work/examples-v2/cxx/cxx_throw/o-optimize/cxx_throw.exe
>>> Hey I'm in base class constructor number 1 for 0x2068384.
>>> Hey I'm in base class constructor number 2 for 0x206837c.
>>> Hey I'm in derived class constructor number 3 for 0x206837c.
>>> *** CONSTRUCTOR/DESTRUCTOR TEST ***
>>> Hey I'm in base class constructor number 4 for 0x20730f0.
>>> Hey I'm in base class constructor number 5 for 0x20730f8.
>>> Hey I'm in base class constructor number 6 for 0x2073100.
>>> Hey I'm in base class constructor number 7 for 0x2073108.
>>> Hey I'm in derived class constructor number 8 for 0x2073108.
>>> Testing a C++ I/O stream
>>> before try block
>>> Breakpoint 1, _Terminate (
>>> the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>>> is_internal=is_internal at entry=false,
>>> the_error=the_error at entry=34011320)
>>> at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:36
>>> 36 {
>>> (gdb) bt
>>> #0 _Terminate (the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>>> #1 0x0203c454 in rtems_fatal (
>>> source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>>> error=error at entry=34011320)
>>> at ../../../../../../rtems/c/src/../../cpukit/sapi/src/fatal2.c:34
>>> #2 0x02035f48 in bsp_spurious_handler (trap=263, isf=0x20721d8)
>>> at
>>> ../../../../../../../../rtems/c/src/lib/libbsp/sparc/erc32/startup/spurious.c:131
>>> #3 0x0205fda4 in dont_fix_pil2 ()
>>> at
>>> ../../../../../../../../rtems/c/src/lib/libbsp/sparc/erc32/../../sparc/shared/irq_asm.S:476
>>> #4 0x0205fda4 in dont_fix_pil2 ()
>>> at
>>> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
>>> (gdb)
>>> at
>>> at
>>> at
>>> (gdb)
>>> [1] I am not feeling 100% well and am at home today. So don't have
>>> access to everything not inclination to hunt.
>>> On 4/1/2014 10:21 AM, Joel Sherrill wrote:
>>> I am confused. Did you build RTEMS with --enable-cxx?
>>> Did you make the linkcmds changes discussed?
>>> In RTEMS, the C++ global constructors are called by the first thread
>>> that executes. Before that, almost anything a constructor is allowed
>>> to do that is not pure computation or memory initialization would
>>> not be valid because the OS and tasking are not running.
>>> There is a call in _Thread_Handler to the constructor execution method.
>>> The name varies by target so it is a macro named INIT. A few lines of code
>>> later the user init task is invoked.
>>> Let's keep this on rtems-users so others benefit from the discussion.
>>> --joel
>>> On 3/27/2014 9:00 PM, Thomas (Gmail) wrote:
>>> On referencing, I misunderstood that _init() call not C++ constructor
>>> function because there is not C++ constructor function in crti.o.
>>> Today, after I make object dump file about elf file(cxx_throw.exe), I
>>> checked that below objdump information. It included ++ constructor as like
>>> below;
>>> 02066130 <_init>:
>>> 2066130: 9d e3 bf a0 save %sp, -96, %sp
>>> 2066134: 7f fe 6c 60 call 20012b4 <frame_dummy>
>>> 2066138: 01 00 00 00 nop
>>> 206613c: 7f ff e8 99 call 20603a0 <__do_global_ctors_aux>
>>> 2066140: 01 00 00 00 nop
>>> 2066144: 81 e8 00 00 restore
>>> 2066148: 81 c3 e0 08 retl
>>> 206614c: 01 00 00 00 nop
>>> I am sorry for my misunderstanding.
>>> Best Regards
>>> 2014-03-28 10:19 GMT+09:00 Thomas (Gmail) <thomas73.kim at gmail.com>:
>>>> Please check that my modification is correct.
>>>> I modified linkcmds.base according to your comment.
>>>> (Before)
>>>> KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>>>> KEEP (*(SORT(.ctors.*)))
>>>> KEEP (*(.ctors))
>>>> KEEP (*crtbegin.o(.dtors))
>>>> KEEP (*crtbegin?.o(.dtors))
>>>> KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>>>> KEEP (*(SORT(.dtors.*)))
>>>> KEEP (*(.dtors))
>>>> (After)
>>>> KEEP (*(.ctors*))
>>>> KEEP (*(.dtors*))
>>>> Also, I compared map file.
>>>> (Before)
>>>> *(.ctors)
>>>> .ctors 0x0206040c 0x4
>>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtend.o
>>>> *crtbegin.o(.dtors)
>>>> .dtors 0x02060410 0x4
>>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.8.2/crtbegin.o
>>>> *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
>>>> *(SORT(.dtors.*))
>>>> *(.dtors)
>>>> (After)
>>>> *(.ctors*)
>>>> *crtbegin.o(.dtors)
>>>> *(SORT(.dtors.*))
>>>> *(.dtors*)
>>>> Best Regards
>>>> 2014-03-28 2:00 GMT+09:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>> I am out of the country and teaching this week. Trying adding an
>>>>> "*" after ctors and before the parentheses. Ditto for dtors so it wild
>>>>> card matches.
>>>>> Look at how .text has a * on it
>>>>> On 3/27/2014 10:25 AM, Thomas (Gmail) wrote:
>>>>> I am tring to compare linkcmd.base and toolchain's elf32_sparc.x.
>>>>> But, I am difficult to modify linkcmd.base for this.
>>>>> Please could you send to me the revised linkcmd.base file ?
>>>>> 2014-03-27 18:18 GMT+09:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>> libgcc2 is already in the toolset. This almost 100% certainly is a
>>>>>> small
>>>>>> bug in c/src/lib/libbsp/sparc/shared/startup/linkcmds.base. Look
>>>>>> at how the .ctors are referenced in the files elf32_sparc.x* installed
>>>>>> as part of the toolset in $prefix/sparc-rtems4.11/lib/ldscripts. They
>>>>>> have "." and a "*" in the KEEP lines. I don't think we have that.
>>>>>> The problem was almost certainly introduced with function sections
>>>>>> being used and I missed a wildcard on the ctor/dtor lines.
>>>>>> On 3/27/2014 3:04 AM, Thomas (Gmail) wrote:
>>>>>> On referencing, I am a beginner regarding this.
>>>>>> As I know from googling information, name of the section for
>>>>>> constructor is in .ctors section in linkcmds.base.
>>>>>> below reference code is from gcc-4.8.2/libgcc/libgcc2.c
>>>>>> because __do_global_ctors() function is in libgcc2.c, I tried to add
>>>>>> libgcc.a in rtems building environment. but, I didn't complete.
>>>>>> < libgcc2.c >
>>>>>> /* Run all the global destructors on exit from the program. */
>>>>>> void
>>>>>> __do_global_ctors (void)
>>>>>> #ifdef EH_FRAME_SECTION_NAME
>>>>>> static struct object object;
>>>>>> __register_frame_info (__EH_FRAME_BEGIN__, &object);
>>>>>> #endif
>>>>>> DO_GLOBAL_CTORS_BODY;
>>>>>> atexit (__do_global_dtors);
>>>>>> < gbl-ctors.h>
>>>>>> /* Some systems use a different strategy for finding the ctors.
>>>>>> For example, svr3. */
>>>>>> #ifndef DO_GLOBAL_CTORS_BODY
>>>>>> #define DO_GLOBAL_CTORS_BODY \
>>>>>> do { \
>>>>>> unsigned long nptrs = (unsigned long) __CTOR_LIST__[0]; \
>>>>>> unsigned i; \
>>>>>> if (nptrs == (unsigned long)-1) \
>>>>>> for (nptrs = 0; __CTOR_LIST__[nptrs + 1] != 0; nptrs++); \
>>>>>> for (i = nptrs; i >= 1; i--) \
>>>>>> __CTOR_LIST__[i] (); \
>>>>>> } while (0)
>>>>>> #endif
>>>>>> 2014-03-27 16:33 GMT+09:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>>> On 3/27/2014 2:30 AM, Sebastian Huber wrote:
>>>>>>>> On 2014-03-27 06:28, Thomas (Gmail) wrote:
>>>>>>>>> I am tring to add libgcc.a in linking process for calling
>>>>>>>>> __do_global_ctors().
>>>>>>>> If you have to do this by hand, then your build process is broken.
>>>>>>>> How did you
>>>>>>>> get the RTEMS tool chain? Which RTEMS version do you use?
>>>>>>>>> Please could you let me know how to add libgcc.a in RTEMS building
>>>>>>>>> environment ?
>>>>>>>>> If this approach is not correct, please let me know correct
>>>>>>>>> how-to-do for C++
>>>>>>>>> global constructor for Sparc.
>>>>>>>> It should work out of the box.
>>>>>>> Just out of curiosity what is the name of the section that the
>>>>>>> constructor is in?
>>>>>>> When I turned on function sections, it may now be in .initXXX instead
>>>>>>> of
>>>>>>> just .init.
>>>>>>> This would mean that an asterisk is needed in the linkcmds.base for
>>>>>>> init
>>>>>>> and fini
>>>>>>> to pick up all the methods. There is a KEEP() around them which I
>>>>>>> thought might
>>>>>>> be the issue.
>>>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>>>> Support Available (256) 722-9985
>> Sent from my Android phone with K-9 Mail. Please excuse my brevity.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
