Installing interrupts for a custom driver
Needell Gerald jerry.needell at unh.edu
Mon Apr 7 13:00:30 UTC 2014
Alberto,
Sorry. Looks like more incorrect advice from me. The generated code looks fine to me. I should know better than to blame the compiler ;-)
I don’t see any obvious reasons why this should not work.
What BSP are you using? What version of RTEMS?
- Jerry
On Apr 7, 2014, at 7:49 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
> Alberto,
> One minor thing.
> Your interrupt handler should begin:
> rtems_isr UARTInterruptHandler(rtems_vector_number vector)
> This is how RTEMS will call it.
> Just a thought,
> I wonder if you are having a problem since the compiler sees the global uc_intr_flag set to 0 then tested against ==1 without being accessed it may be “helping” you by not actually executing the loop as you have it written. You may want to examine the generated code to be sure it is doing what you think.
> Try just incrementing a counter in your ISR and see if it gets incremented in your while(1) loop.
> - Jerry
> On Apr 7, 2014, at 6:58 AM, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>> I have tried the set_vector functions and didn't work either. I though that Driver Manager may be interfering with the interrupt controller driver and I decided to avoid it by "#undef RTEMS_DRVMGR_STARTUP" and see if my handler was being called, but nothing at all. Then I wanted to know if the interrupt was being signaled in the interrupt controller so I went to the IRQ Pending register of the GAISLER_IRQMPIP Core, and as soon as I introduce any character from external terminal towards the APBUART, the Interrupt is shown in the register, but my handler is never called.
>> It is quite disappointing, I have to say. Installing an interrupt should be something easy to do, or at least it has been when working with other OS ... I don't know. Any help will be welcome.
>> Alberto.
>> De: Needell Gerald <jerry.needell at unh.edu>
>> Para: Alberto Parnaso <pafbat00 at yahoo.es>
>> CC: Needell Gerald (Jerry) <jerry.needell at unh.edu>; RTEMS Send User List <rtems-users at rtems.org>
>> Enviado: Viernes 4 de abril de 2014 18:09
>> Asunto: Re: Installing interrupts for a custom driver
>> You should be able to just call:
>> old_handler = setvector((rtems_isr_entry)UARTInterruptHandler, (rtems_vector_number)3, 1);
>> On Apr 4, 2014, at 11:37 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
>> Alberto,
>> No. My suggestion is to use the rtems_interrupt_catch but then enable the interrupt as in the example .
>> -Jerry
>> On Apr 4, 2014, at 11:33, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>>> Hi Jerry, thank you very much for your response. If I have understand correctly I may have to install the interrupt not with "rtems_interrupt_catch" but using "_CPU_ISR_install_raw_handler". Is that correct? I am out of work now but I will test it on Monday and come back with the results. Thanks indeed!
>>> Alberto.
>>> CC: Jerry Needell <jerry.needell at unh.edu>; RTEMS Send User List <rtems-users at rtems.org>
>>> Enviado: Viernes 4 de abril de 2014 16:25
>>> Alberto,
>>> This may not have been correct- Take a look at the     c/src/lib/libbsp/sparc/leon3/startup/setec.c function from the LEON3 BSP (RTEMS 4.9.2) - attached:
>>> After calling rtems_catch_interrupt the LEON3 interrupt is then enabled - I install my handlers as a type=1  RTEMS interrupt.
>>> I hope that helps
>>> - Jerry
>>> /*  set_vector
>>>  *  This routine installs an interrupt vector on the SPARC simulator.
>>>  *  INPUT PARAMETERS:
>>>  *    handler - interrupt handler entry point
>>>  *    vector  - vector number
>>>  *    type    - 0 indicates raw hardware connect
>>>  *              1 indicates RTEMS interrupt connect
>>>  *  OUTPUT PARAMETERS:  NONE
>>>  *  RETURNS:
>>>  *    address of previous interrupt handler
>>>  *  COPYRIGHT (c) 1989-1998.
>>>  *  On-Line Applications Research Corporation (OAR).
>>>  *  The license and distribution terms for this file may be
>>>  *  found in the file LICENSE in this distribution or at
>>>  *  http://www.rtems.com/license/LICENSE.
>>>  *  Ported to LEON implementation of the SPARC by On-Line Applications
>>>  *  Research Corporation (OAR) under contract to the European Space
>>>  *  Agency (ESA).
>>>  *  LEON modifications of respective RTEMS file: COPYRIGHT (c) 1995.
>>>  *  European Space Agency.
>>>  *  $Id: setvec.c,v 1.2 2006/01/09 10:41:21 ralf Exp $
>>> #include <bsp.h>
>>> rtems_isr_entry set_vector(                   /* returns old vector */
>>>   rtems_isr_entry     handler,                /* isr routine        */
>>>   rtems_vector_number vector,                 /* vector number      */
>>>   int                 type                    /* RTEMS or RAW intr  */
>>>   rtems_isr_entry previous_isr;
>>>   uint32_t      real_trap;
>>>   uint32_t      source;
>>>   if ( type )
>>>     rtems_interrupt_catch( handler, vector, &previous_isr );
>>>   else
>>>     _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
>>>   real_trap = SPARC_REAL_TRAP_NUMBER( vector );
>>>   if ( LEON_INT_TRAP( real_trap ) ) {
>>>     source = LEON_TRAP_SOURCE( real_trap );
>>>     LEON_Clear_interrupt( source );
>>>     LEON_Unmask_interrupt( source );
>>>   return previous_isr;
>>> On Apr 4, 2014, at 9:33 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
>>> Alberto,
>>> If I recall correctly, rtems_interrupt_catch  installs the new interrupt handler, but does not enable it. You will also need to call rtems_interrupt_enable.
>>> Good luck!
>>> Jerry
>>> On Apr 4, 2014, at 9:12 AM, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>>>> Hi, I am newbie in RTEMS and I am trying to install an interrupt into the interrupt controller to be capable of using an APBUART peripheral within a LEON3 based embedded processor. I configure the system so driver manager configures at BSP Start the console and the timer. I do have two APBUART configured in the system and my intention is to use the first one with console/termios driver and the second one with my own driver. Here is a copy the output of "info sys" command:
>>>> grmon2> info sys
>>>>           cpu0          Aeroflex Gaisler  LEON3 SPARC V8 Processor
>>>>                   AHB Master 0
>>>>           ahbjtag0  Aeroflex Gaisler  JTAG Debug Link
>>>>                       AHB Master 1
>>>>           mctrl0    European Space Agency  LEON2 Memory Controller
>>>>                       AHB: 00000000 - 20000000
>>>>                       AHB: 20000000 - 40000000
>>>>                       AHB: 40000000 - 80000000
>>>>                       APB: 80000000 - 80000100
>>>>                       32-bit prom @ 0x00000000
>>>>                       32-bit static ram: 2 * 512 kbyte @ 0x40000000
>>>>           apbmst0   Aeroflex Gaisler  AHB/APB Bridge
>>>>                   AHB: 80000000 - 80100000
>>>>           dsu0      Aeroflex Gaisler  LEON3 Debug Support Unit
>>>>                    AHB: 90000000 - A0000000
>>>>           CPU0:  win 8, hwbp 2, V8 mul/div, lddel 1, GRFPU-lite
>>>>                   stack pointer 0x400ffff0
>>>>                           icache 1 * 4 kB, 32 B/line
>>>>                   dcache 1 * 4 kB, 32 B/line
>>>>           uart0        Aeroflex Gaisler  Generic UART
>>>>                   APB: 80000100 - 80000200
>>>>                   IRQ: 2
>>>>                   Baudrate 38343
>>>>           irqmp0    Aeroflex Gaisler  Multi-processor Interrupt Ctrl.
>>>>                   APB: 80000200 - 80000300
>>>>           gptimer0  Aeroflex Gaisler  Modular Timer Unit
>>>>                   APB: 80000300 - 80000400
>>>>                   IRQ: 8
>>>>                   8-bit scalar, 2 * 32-bit timers, divisor 50
>>>>           uart1     Aeroflex Gaisler  Generic UART
>>>>                   APB: 80000900 - 80000A00
>>>>                   IRQ: 3
>>>>                   Baudrate 38343
>>>>           gpio0     Aeroflex Gaisler  General Purpose I/O port
>>>>                   APB: 80000B00 - 80000C00
>>>> I have wrote a testing app to check if both UARTs work and also to try to install a handler for RX on the second UART. Here is my code:
>>>> #include <rtems.h>
>>>> rtems_task Init( rtems_task_argument argument);    /* forward declaration needed */
>>>> /* configuration information */
>>>> #define CONFIGURE_INIT
>>>> #include <bsp.h> /* for device driver prototypes */
>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> #define CONFIGURE_MAXIMUM_TASKS             4
>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> #include <rtems/confdefs.h>
>>>> #include <stdio.h>
>>>> #include <stdlib.h>
>>>> #include <sys/types.h>
>>>> #include <sys/stat.h>
>>>> #include <unistd.h>
>>>> #include <errno.h>
>>>> #include <apbuart.h>
>>>> // Global Variable to check if Interrupt has been signaled.
>>>> unsigned char uc_intr_flag;
>>>> // Interrupt handler for APBUART peripheral
>>>> void UARTInterruptHandler ()
>>>>     uc_intr_flag = 1;
>>>> rtems_task Init (rtems_task_argument ignored)
>>>>     int i;
>>>>     rtems_status_code ret_status;
>>>>     rtems_isr_entry old_handler;
>>>>     volatile int *apbuart1 = (int*)0x80000900;
>>>>     volatile int aux;
>>>>     // Reset Interrupt Flag
>>>>     uc_intr_flag = 0;
>>>>     printf("APB UART TEST with Interrupts\n");
>>>>     aux = apbuart1[1];
>>>>     printf("APBUART1 STATUS: 0x%08X\n", aux);
>>>>     aux = apbuart1[2];
>>>>     printf("APBUART1 CONTROL: 0x%08X\n", aux);
>>>>     // Install UARTInterruptHandler at vector number 3
>>>>     ret_status = rtems_interrupt_catch(
>>>>             &old_handler);
>>>>     switch (ret_status)
>>>>            case RTEMS_SUCCESSFUL :
>>>>               printf("rtems_interrupt_catch: OK. New Interrupt installed for IRQ 3 - APBUART 2.\n");
>>>>           break ;
>>>>            case RTEMS_INVALID_NUMBER :
>>>>               printf("rtems_interrupt_catch: RTEMS_INVALID_NUMBER.\n");
>>>>               break ;
>>>>            case RTEMS_INVALID_ADDRESS :
>>>>                printf("rtems_interrupt_catch: RTEMS_INVALID_ADDRESS.\n");
>>>>                break ;
>>>>         default :
>>>>               printf("rtems_interrupt_catch: Unknown error.\n");
>>>>               break ;
>>>>     // Tell uart hardware to initialize directly
>>>>     /* Enable receiver (with interrupts) & Transmitter */
>>>>     apbuart1[2] = APBUART_CTRL_RE | APBUART_CTRL_TE | APBUART_CTRL_RI;
>>>>     aux = apbuart1[1];
>>>>     printf("UART1 STATUS: 0x%02X\n", aux);
>>>>     aux = apbuart1[2];
>>>>     printf("UART1 CONTROL: 0x%08X\n", aux);
>>>>     // Write a character though APBUART1 to test it
>>>>     apbuart1[0] = 0xD8;
>>>>     while (1)
>>>>     {       // Perform some active wait time
>>>>         for (i = 2000000; i > 0; i--);
>>>>         printf("Hello World\n");
>>>>         apbuart1[0] = 0xD8;
>>>>         // If interrupt received, read from APBUART
>>>>         if (uc_intr_flag == 1)
>>>>             uc_intr_flag = 0;
>>>>             aux = apbuart1[0];
>>>>             printf("Interrupt received from UART: data = %X\n", aux);
>>>>     exit (0);
>>>> First UART (ie. debug UART) works fine and output data through STDOUT properly. Data sent through second UART is received also by another external terminal, and in other test I have been capable of receiving too. However UARTInterruptHandler is never signaled, thus I guess I am missing something with the interrupt instalation.
>>>> Could any one see anything missing in this code? I would very much appreciate some help. Any clue on how to properly use interrupts will help me a lot!
>>>> Thanks!
>>>> Alberto.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140407/e4247913/attachment-0001.html>
