getcwd syscall fails on 3rd subfolder
Chris Johns
chrisj at rtems.org
Thu Apr 10 01:58:30 UTC 2014
On 9/04/2014 9:46 pm, Hoefle Marco wrote:
> Hello Chris,
> The root is IMFS and the FAT12 partition is mounted to /mnt
> Let me explain how the fatfs image is linked to the application:
> 1) a fat12 image is generated using:
> /sbin/mkfs.vfat -F 12 -S 512 -s 1 -r 512 -f 1 -v fs_image
I assume this is some sort of Linux type command.
> 2) the image is initialized with default folders/files:
> mcopy -b/ -i fs_image) content/* ::/
Ok.
> 3) a C array is generated using:
> xxd -i fs_image > fs_image.c
Ok.
> 4) This large C file is compiled and linked into the RTEMS application.
> I wanted to use a FAT32 image first but that didn't work at all. RTEMS
> mount was successful but the mounted disk was empty.
> Could it be that the image generated with mkfs.vfat is not compatible
> with the RTEMS dosfs implementation?
It could be or it could a bug in RTEMS. It is hard to say. I do not have
this kernel available to try and test with.
Are you in a position to the latest RTEMS kernel from git ?
> This is how the FAT12 disk is mounted:
> extern unsigned int fatfs_image_len;
> extern unsigned char fatfs_image[];
> * The RAM Disk configuration.
> rtems_ramdisk_config rtems_ramdisk_configuration[] =
> .block_size = 512,
> .location = fatfs_image
> * The number of RAM Disk configurations.
> size_t rtems_ramdisk_configuration_size = 1;
> * Create the RAM Disk Driver entry.
> rtems_driver_address_table rtems_ramdisk_io_ops = {
> initialization_entry: ramdisk_initialize,
> open_entry: rtems_blkdev_generic_open,
> close_entry: rtems_blkdev_generic_close,
> read_entry: rtems_blkdev_generic_read,
> write_entry: rtems_blkdev_generic_write,
> control_entry: rtems_blkdev_generic_ioctl
> static int setup_ramdisk (const char* mntpath)
> rtems_device_major_number major;
> rtems_status_code sc;
> rtems_ramdisk_configuration[0].block_num =
> fatfs_image_len /
> rtems_ramdisk_configuration[0].block_size;
> sc = rtems_io_register_driver (
> RTEMS_DRIVER_AUTO_MAJOR,
> &rtems_ramdisk_io_ops,
> &major);
> if (sc != RTEMS_SUCCESSFUL) {
> nts_printf ("error: ramdisk driver not initialised:
> %s\n",
> rtems_status_text (sc));
> return NTS_FAILURE;
> nts_printf ("RAM Disk registered\n");
> mkdir(mntpath, 0777);
> sc = mount("/dev/rda", mntpath, "dosfs",
> RTEMS_FILESYSTEM_READ_WRITE, NULL);
> nts_printf("mount return: %d\n", sc);
> nts_printf("ram disk addr: 0x%08x\n", (unsigned int)
> (rtems_ramdisk_configuration[0].location));
> return NTS_OK;
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Mittwoch, 9. April 2014 03:06
> To: Hoefle Marco; rtems-users at rtems.org
> Subject: Re: getcwd syscall fails on 3rd subfolder
> On 8/04/2014 10:22 pm, Hoefle Marco wrote:
>>> Hello,
>>> we use the Gaisler RTEMS Kernel 4-10-1.2.14 on a GR712RC board.
>> I have not used their version or hardware.
>>> The following function is used to determine the current working
>>> directory on a fatfs:
>>> static NtsError fs_pwd_do( int argc, char **argv)
>>> char *ret = getcwd(NULL, 0);
>>> if(ret) {
>>> nts_printf("%s\n", ret);
>>> free(ret);
>>> return NTS_OK;
>>> nts_printf("getcwd failed, errno: %d, MAXPATHLEN: %d\n",
> errno,
>>> MAXPATHLEN);
>>> return NTS_FAILURE;
>>> The fatfs was generated using:
>>> @dd if=/dev/zero of=$(NAME) bs=256 count=1024 > /dev/null
>> /sbin/mkfs.vfat -F 12 -S 512 -s 1 -r 512 -f 1 -v $(NAME)
>> This is what happens:
>> cassis> fs mount
>> RAM Disk registered
>> mount return: 0
>> ram disk addr: 0x64000000
> This would seem to be a root disk. Is this an IMFS disk or a RAM disk ?
>> cassis> fs ls
>> 3920 dev
>> 16384 mnt
>> cassis> fs pwd
>> cassis> fs cwd mnt
>> changed to mnt
>> cassis> fs pwd
>> /mnt
>> cassis> fs ls
>> 512 template
>> cassis> fs cwd template
>> changed to template
>> cassis> fs pwd
>> /mnt/template
>> cassis>
>> cassis> fs ls
>> 512 .
>> 16384 ..
>> 512 param
>> 512 logs
>> cassis> fs cwd logs
>> changed to logs
>> cassis> fs pwd
>> getcwd failed, errno: 2, MAXPATHLEN: 1024
> The getcwd code looks up the path to the parent until the root to build
> the path. There maybe something wrong here if the root is not IMFS.
> Chris
>> cassis>
>> The folder logs is definitely existing:
>> cassis> fs dump /mnt/template/logs/housekeeping/log0
>> file size: 10
>> 64 61 63 30 3a 20 31 30 30 0a
>> A non existing file leeds to:
>> cassis> fs dump /mnt/template/logs/housekeeping/log9
>> file size: 10
>> failure, ret: -1, errno: 2
>> Has anybody an idea why getcwd() fails (errno 2 means not existent)?
>> Cheers,
>> Marco
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
