Overwriting of device block size from fat_init_volume_info
Sebastian Huber
Tue Apr 22 06:22:00 UTC 2014
Hello Ali,
On 2014-04-20 04:18, ali nasir wrote:
> Hi,
> In the RTEMS4.11 i see that the block device's block size is overwritten in the
> rtems_disk_device depending on the cluster size or the alignment of the block
> device.
> We are migrating from 4.10.2 to 4.11. The block device we use is SD card. The
> ioctl just checks for the bufnum field and reads those number of blocks from
> the device. However, in the rtems4.11, with one particular SD card, the fat
> overwrites the block size to 4K from 512. But the ioctl is not aware of the
> same. Hence when the FAT tries to read a single block, it assumes that it will
> get 4K of data. But the ioctl just sends out 512 bytes to the FAT layer.
> How should i take care of the overwriting of the block size by FAT? The block
> device is created,at start up, with a block size of 512. Should the ioctl check
> the block size in the rtems_disk_device pointer which the ioctl receives?
the block device cache uses two block sizes. One is the media block size which
is the minimum transfer unit of a particular device/driver. The other is the
block size used by the cache. It must be an integral multiple of the media
block size.
I guess your driver doesn't evaluate the block device transfer request correctly.
* @brief Block device scatter or gather buffer structure.
typedef struct rtems_blkdev_sg_buffer {
* Block index.
rtems_blkdev_bnum block;
* Buffer length.
uint32_t length;
* Buffer pointer.
void *buffer;
* User pointer.
void *user;
} rtems_blkdev_sg_buffer;
Please note that the length here may be an integral multiple of the media block
size.
> This change in the fat_init_volume_info (to rewrite the block size) should be
> there in the release notes as there is a chance that the ioctl's, which were
> working with 4.10, may fail with 4.11.
We will add something to the release notes.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
