Overwriting of device block size from fat_init_volume_info
Sebastian Huber
Tue Apr 22 06:56:45 UTC 2014
On 2014-04-22 08:45, ali nasir wrote:
> Yes. I noticed that the length is an integral multiple of the media block size.
> So is this length field reliable enough to be used as a mesaure to determine
> how many blocks to read from the device.
The length field is guaranteed to be an integral multiple of the media blocks size.
> For e.g. if the media block size is 512 and the length field is 4096. Should i
> interpret in the device driver (ioctl) that the request is to read 8 blocks of
> data (4096/512)?
Yes.
> I was trying to read the block_size field of the struct rtems_disk_device. But
> the ioctl receives the pointer to the physical device and the block_size of the
> physical device is set to the media_block_size (512 in my case). There is no
> relation in the physical device pointer to the logical device (the partition on
> the disk).
You should only use the rtems_disk_device dd for rtems_disk_get_driver_data(dd)
and for all other information the rtems_blkdev_request.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
