Issue with Task delete
ali nasir supremenasir at yahoo.com
Wed Apr 23 12:30:09 UTC 2014
Hi,
I cloned the RTEMS GIT just before Christmas last year (around 20 or 19th Dec 2013).
Should i clone the RTEMS git or also the newlib?
Is newlib 2.1.0 ok to use? Since I see that the rtems-m68k.bset suggests to use the newlib 2.1.0- 1
We use the m5485FireEngine bsp.
# Tools configuration.
4.11/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-binutils-2.24-1
tools/rtems-gcc-4.8.2-newlib-2.1.0-1
tools/rtems-gdb-7.6.2-1
tools/rtems-kernel-4.11
-Ali
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: ali nasir <supremenasir at yahoo.com>
Cc: "rtems-users at rtems.org" <rtems-users at rtems.org>
Sent: Wednesday, April 23, 2014 3:34 PM
Subject: Re: Issue with Task delete
Hello Ali,
with the latest Newlib and RTEMS version the test works on a simulator BSP.
Which Git revision do you use?
On 2014-04-23 11:43, ali nasir wrote:
> I am not sure, what does it wait for as i cannot see the task in the OS. There
> is a call to fwalk (which is called from _reclaim_reent) from the
> newlib_delete_hook which never returns. There is no crash of the system.
> I also noticed that further dynamic memory allocations are blocked for the
> tasks which are already launched.
> I see if there is an fprintf call from this task, only then we see the problem.
> If there is no fprintf, then everything works fine. This could be the clue to
> find the problem.
The newlib_delete_hook no longer exists.  I recently changed the thread
deletion code to fix a couple of problems.  Can you please update to the latest
Git master and see if the problem is still present.
Phone  : +49 89 189 47 41-16
Fax    : +49 89 189 47 41-09
E-Mail  : sebastian.huber at embedded-brains.de
PGP    : Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140423/f87b9df5/attachment-0001.html>
