Bug with MPC55XX eSCI serial port byte size and parity?
Peter Dufault dufault at hda.com
Sat Aug 23 19:22:09 UTC 2014
On Aug 23, 2014, at 09:56 , Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> That all sounds very reasonable and since you have the hardware, you can check that it works. The interactive termios test is good for manually cycling through all the various settings. Change them on the target, then your comma program, see if the output is still right and then check another setting.
My major question is how TERMIOS, data size, and parity should work.  To me it's vague.  If it's agreed that 7 bit data with parity is 8 bits of data and 8 bit data with parity is 9 bits of data then I'll make up a patch.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
