CVS access failures
Thu Aug 28 18:59:11 UTC 2014
I would avoid the RPMs, they are badly outdated.
On 8/28/14, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
> Hi David,
> On Thu, Aug 28, 2014 at 7:44 PM, Shifflett, David (CIV)
> <shifflett at nps.edu> wrote:
>> I am trying to build on a Fedora 19 system.
>> I am getting a 'connection refused' error when it tries to checkout
>> newlib from sourceware.org
>> It is possible that CVS is being blocked by my IT department,
>> I am looking into that.
>> Can someone confirm that the CVS server at sourceware.org
>> is up and accessible?
>> If CVS access is being blocked,
>> what alternatives do I have for getting things built?
> You may find an alternative way of building the tool-chain by
> accessing this link [1] which contains rpm packages for fedora 19.
> First download and run yum configure rpm [2], and then you can run
> 'yum install rtems-4.11-auto*' for auto-tools and 'yum install
> rtems-4.11-sparc-rtems4.11-*' to install the sparc tool-chain.
> [1] http://rtems.org/ftp/pub/rtems/linux/4.11/fedora/19/x86_64/
> [2]
> http://rtems.org/ftp/pub/rtems/linux/4.11/fedora/19/x86_64/rtems-4.11-yum-conf-0.20140713.0-1.fc19.noarch.rpm
> Hope you find my reply useful.
> Regards,
> Hesham
>> Build command:
>> ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
>> Tail of error log:
>> script: 84: cd ${build_top}
>> script: 85: source_dir_newlib="newlib-19-Aug-2014"
>> source setup: sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1: source
>> newlib -q -D -n newlib-19-Aug-2014
>> Creating source directory: sources/cvs
>> making dir:
>> /home/user/development/rtems/src/rtems-source-builder/rtems/sources/cvs
>> sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_19_Aug_2014
>> cvs: checkout: cvs://pserver:anoncvs@sourceware.org/cvs/src ->
>> cmd:
>> (/home/user/development/rtems/src/rtems-source-builder/rtems/sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_19_Aug_2014)
>> /usr/bin/cvs -z 9 -q -d :pserver:anoncvs at sourceware.org/cvs/src co -N -D
>> 19-Aug-2014 newlib
>> cvs [checkout aborted]: connect to [sourceware.org]:2401 failed:
>> Connection refused
>> error: cvs command failed (['/usr/bin/cvs', '-z', '9', '-q', '-d',
>> ':pserver:anoncvs at sourceware.org/cvs/src', 'co', '-N', '-D',
>> '19-Aug-2014', 'newlib']): 1
>> I also tried to access CVS from the command line
>> and got the same 'connection refused' error.
>> THanks for any help,
>> dave
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
