source-builder / ARM
Pierre Ficheux pierre.ficheux at openwide.fr
Fri Aug 29 09:19:50 UTC 2014
Hi Chris,
Thx for the answer, I did a stupid cut/paste...works fine.
regards
----- Mail original -----
> De: "Chris Johns" <chrisj at rtems.org>
> À: "Pierre Ficheux" <pierre.ficheux at openwide.fr>, "rtems-users" <rtems-users at rtems.org>
> Envoyé: Vendredi 29 Août 2014 03:07:32
> Objet: Re: source-builder / ARM
> On 29/08/2014 1:28 am, Pierre Ficheux wrote:
> > Hi all,
> > I'm back to RTEMS for some time.
> > I've tried 'rtems-source-builder' but it seems to build everything
> > including RTEMS source tree (for all ARM bsp's...).
> > $ <path>/source-builder/sb-set-builder --log=l-test.txt
> > --prefix=<path>/4.11 --with-rtems 4.11/rtems-arm
> > I would like to build SDK only, so I think I just have to create a
> > new .bset file from config/4.11/rtems-arm.bset
> > *without* tools/rtems-kernel-4.11 line.
> You could just remove the '--with-rtems' option from the command
> line.
> Maybe this option should be '--with-rtems-kernel' ? I can see
> '--with-rtems' as being confusing.
> Chris
Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux at openwide.fr
                                         http://ingenierie.openwide.fr
                                         http://www.linuxembedded.fr
I would love to change the world, but they won't give me the source code
