CVS access failures
Fri Aug 29 18:08:19 UTC 2014
On 8/29/2014 10:49 AM, David Shifflett wrote:
> Chris,
> Thanks for your efforts.
> I still haven't been able to determine if my IT department is blocking CVS.
> Can you confirm that you can access the CVS server at sourceware.org?
> When I try 'cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src login'
> I get a prompt to enter a password 'anoncvs',
> but then I get a 'connection refused' error.
>From oarcorp.com:
-bash-4.2$ cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src login
Logging in to :pserver:anoncvs at sourceware.org:2401/cvs/src
CVS password:
-bash-4.2$
pserver is port 2401 so you can use telnet to test the connection:
-bash-4.2$ telnet sourceware.org 2401
Trying 209.132.180.131...
Connected to sourceware.org.
Escape character is '^]'.
cvs [pserver aborted]: bad auth protocol start:
Connection closed by foreign host.
--joel
> dave
> On 8/28/14 6:05 PM, Chris Johns wrote:
>> On 29/08/2014 3:46 am, Federico Casares wrote:
>>> Same error happens to me yesterday... IT block :P
>> Ouch.
>>> regards
>>> On Thu, Aug 28, 2014 at 2:44 PM, Shifflett, David (CIV)
>>> <shifflett at nps.edu <mailto:shifflett at nps.edu>> wrote:
>>>     I am trying to build on a Fedora 19 system.
>>>     I am getting a 'connection refused' error when it tries to checkout
>>>     newlib from sourceware.org <http://sourceware.org>
>>>     It is possible that CVS is being blocked by my IT department,
>>>     I am looking into that.
>>>     Can someone confirm that the CVS server at sourceware.org
>>>     is up and accessible?
>>>     If CVS access is being blocked,
>>>     what alternatives do I have for getting things built?
>> I will figure out a suitable work around using the user macro feature.
>> Joel, I think we need to consider a CVS snapshot approach. Newlib seems
>> stable and doing this gets us back to http or ftp get.
>> Chris
> users mailing list
> users at rtems.org
