CVS access failures
David Shifflett shifflett at nps.edu
Fri Aug 29 18:27:14 UTC 2014
Joel,
Good idea, I didn't think to try it using telnet.
I have confirmed that my IT dept. restricts CVS access.
I have gotten that restriction lifted for sourceware.org
Re-building now.
dave
On 8/29/14 11:08 AM, Joel Sherrill wrote:
> On 8/29/2014 10:49 AM, David Shifflett wrote:
>> Chris,
>> Thanks for your efforts.
>> I still haven't been able to determine if my IT department is blocking CVS.
>> Can you confirm that you can access the CVS server at sourceware.org?
>> When I try 'cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src login'
>> I get a prompt to enter a password 'anoncvs',
>> but then I get a 'connection refused' error.
>>From oarcorp.com:
> -bash-4.2$ cvs -z 9 -d :pserver:anoncvs at sourceware.org:/cvs/src login
> Logging in to :pserver:anoncvs at sourceware.org:2401/cvs/src
> CVS password:
> -bash-4.2$
> pserver is port 2401 so you can use telnet to test the connection:
> -bash-4.2$ telnet sourceware.org 2401
> Trying 209.132.180.131...
> Connected to sourceware.org.
> Escape character is '^]'.
> cvs [pserver aborted]: bad auth protocol start:
> Connection closed by foreign host.
> --joel
>> dave
>> On 8/28/14 6:05 PM, Chris Johns wrote:
>>> On 29/08/2014 3:46 am, Federico Casares wrote:
>>>> Same error happens to me yesterday... IT block :P
>>> Ouch.
>>>> regards
>>>> On Thu, Aug 28, 2014 at 2:44 PM, Shifflett, David (CIV)
>>>> <shifflett at nps.edu <mailto:shifflett at nps.edu>> wrote:
>>>>      I am trying to build on a Fedora 19 system.
>>>>      I am getting a 'connection refused' error when it tries to checkout
>>>>      newlib from sourceware.org <http://sourceware.org>
>>>>      It is possible that CVS is being blocked by my IT department,
>>>>      I am looking into that.
>>>>      Can someone confirm that the CVS server at sourceware.org
>>>>      is up and accessible?
>>>>      If CVS access is being blocked,
>>>>      what alternatives do I have for getting things built?
>>> I will figure out a suitable work around using the user macro feature.
>>> Joel, I think we need to consider a CVS snapshot approach. Newlib seems
>>> stable and doing this gets us back to http or ftp get.
>>> Chris
>> users mailing list
>> users at rtems.org
