C++ Constructor Initialization Failure for Cortex-A8
Thomas Kim
thomas73.kim at gmail.com
Mon Dec 1 04:26:52 UTC 2014
Dear Sir,
I am testing cxx example including C++ global constructor in example-v2 on
Cortex-A8 based board.
As I remembered in csae of using cxx example on Sparc SIS, I resolved this
after removing below options according to your comment.
CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
LDFLAGS = -Wl,--gc-sections
But, when I test same cxx example on ARM Cortex-A8 board, I have similar
problem as like below;
terminate called after throwing an instance of
'__gnu_cxx::__concurrence_lock_error'
what(): __gnu_cxx::__concurrence_lock_error
At this time, I used below config options for Cortex-A8.
CPU_CFLAGS = -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp
CFLAGS_OPTIMIZE_V ?= -O2 -g
also, I am using RSB GCC 4.8.2 as like below;
Target: arm-rtems4.11
Configured with: ../gcc-4.8.2/configure --prefix=/opt/rtems-4.11
--bindir=/opt/rtems-4.11/bin --exec_prefix=/opt/rtems-4.11
--includedir=/opt/rtems-4.11/include --libdir=/opt/rtems-4.11/lib
--libexecdir=/opt/rtems-4.11/libexec --mandir=/opt/rtems-4.11/share/man
--infodir=/opt/rtems-4.11/share/info --datadir=/opt/rtems-4.11/share
--build=i686-linux-gnu --host=i686-linux-gnu --target=arm-rtems4.11
--disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose --with-newlib
--with-system-zlib --disable-nls --without-included-gettext
--disable-win32-registry --enable-version-specific-runtime-libs
--disable-lto --enable-newlib-io-c99-formats --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
--enable-threads --disable-plugin --enable-obsolete --enable-languages=c,c++
Thread model: posix
gcc version 4.8.2 20131016 (RTEMS
4.11-RSB-40d25dc8fe6da6b93b295d9b42632c1d3338a97a-1,gcc-4.8.2/newlib-2.1.0)
(GCC)
Please let me know how to resolve this problem ?
Thomas Kim
URL: <http://lists.rtems.org/pipermail/users/attachments/20141201/e184e4a9/attachment.html>
