C++ Constructor Initialization Failure for Cortex-A8
Sebastian Huber
Tue Dec 2 06:55:30 UTC 2014
On 02/12/14 05:04, Thomas Kim wrote:
> Dear Sebastian,
> I am testing cxx_throw.exe on your same environment for
> realview-pbx-a9-qemu.
> When I test below option, it is OK! as like you.
> CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
> -mtune=cortex-a9
> But, When I changed option as like below, cxx_throw.exe just output
> three lines.
> CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=softfp
> -mtune=cortex-a9
The second set of options is not supported by the tool chain. See also
https://devel.rtems.org/wiki/Developer/Architecures/ARM/ARM-EABI
> < Output >
> Hey I'm in base class constructor number 1 for 0x201dcc.
> Hey I'm in base class constructor number 2 for 0x201dd4.
> Hey I'm in derived class constructor number 3 for 0x201dd4.
> Please could you let me know a reason about this result ?
No, you have to debug this if you really want to know what happens.
> Best Regards,
> Thomas Kim
> 2014-12-01 17:27 GMT+09:00 Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>:
> On 01/12/14 09:18, Thomas Kim wrote:
> Do you mean that I should update both lastest RTEMS 4.10.99
> source with GCC 4.8.3(RSB) ?
> This is hard to say. I would start a debugger and try to figure
> out the problem source.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20141202/e3572fc3/attachment.html>
