Context switching for VFP registers on Cortex-A8 board.
Thomas Kim
thomas73.kim at gmail.com
Tue Dec 2 10:51:15 UTC 2014
Dear Sebastian,
You are correct.
My problem is memory alignment issue from u-boot.
I fixed this for adding below statement.
mrc p15, 0, r0, cr1, cr0, 0
ldr r1, =~0x00000002
and r0, r0, r1
mcr p15, 0, r0, cr1, cr0, 0
Thank you very much.
Best Regards,
Thomas Kim
2014-12-02 19:38 GMT+09:00 Thomas Kim <thomas73.kim at gmail.com>:
> Dear Sebastian,
> I used lastest RTEMS source on https://github.com/RTEMS/rtems.
> Is there initialization code(start.S) for handling SCTLR.A bit on current
> source tree ?
> Best Regards,
> Thomas Kim
> 2014-12-02 19:27 GMT+09:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
>> Hello,
>> you use a BSP that is not included in the main RTEMS sources, so I can
>> only guess.
>> On 02/12/14 11:16, Thomas Kim wrote:
>>> Dear Sir.
>>> I completed to port RTEMS on Cortex-A8 board using below option.
>>> CPU_CFLAGS = -march=armv7-a -mtune=cortex-a8 -mfpu=neon
>>> -mfloat-abi=softfp
>>> At this time, RTEMS sample example(ticker.exe) is working very well.
>>> Because there is a problem for executing C++ exception example using
>>> "-mfloat-abi=softfp", I changed below option.
>>> -mfloat-abi=hard
>>> After I rebuild RTEMS using "-mfloat-abi=hard", I am tring to test both
>>> ticker.exe and cxx_throw.exe.
>>> But, both examples are crashed in mount() function of
>>> rtems_filesystem_initialize().
>>> In detailly, memcpy() of alloc_mount_table_entry() is called, exception
>>> is ocurred.
>> There are many exceptions and some provide extra information, so
>> "exception is occurred" is a very vague description.
>> You probably use the wrong memory attributes. Make sure misaligned
>> memory access is possible. See SCTLR.A bit (ARM_CP15_CTRL_A).
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20141202/d13b6ebe/attachment.html>
