Edison paranoia output
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Dec 11 18:09:55 UTC 2014
Hi
Jeff sent this to me and I wanted to make sure it got posted to
the mailing list. paranoia reports flaws in the math.
I don't know how this compares to the native gcc on the Linux
distributed with the Edison.
*** BEGIN OF TEST PARANOIA ***
paranoia version 1.1 [cygnus]
Program is now RUNNING tests on small integers:
TEST: 0+0 != 0, 1-1 != 0, 1 <= 0, or 1+1 != 2
PASS: 0+0 != 0, 1-1 != 0, 1 <= 0, or 1+1 != 2
TEST: 3 != 2+1, 4 != 3+1, 4+2*(-2) != 0, or 4-3-1 != 0
PASS: 3 != 2+1, 4 != 3+1, 4+2*(-2) != 0, or 4-3-1 != 0
TEST: -1+1 != 0, (-1)+abs(1) != 0, or -1+(-1)*(-1) != 0
PASS: -1+1 != 0, (-1)+abs(1) != 0, or -1+(-1)*(-1) != 0
TEST: 1/2 + (-1) + 1/2 != 0
PASS: 1/2 + (-1) + 1/2 != 0
TEST: 9 != 3*3, 27 != 9*3, 32 != 8*4, or 32-27-4-1 != 0
PASS: 9 != 3*3, 27 != 9*3, 32 != 8*4, or 32-27-4-1 != 0
TEST: 5 != 4+1, 240/3 != 80, 240/4 != 60, or 240/5 != 48
PASS: 5 != 4+1, 240/3 != 80, 240/4 != 60, or 240/5 != 48
-1, 0, 1/2, 1, 2, 3, 4, 5, 9, 27, 32 & 240 are O.K.
Searching for Radix and Precision.
Radix = 2.000000 .
Closest relative separation found is U1 = 5.4210109e-20 .
Recalculating radix and precision
confirms closest relative separation U1 .
Radix confirmed.
TEST: Radix is too big: roundoff problems
PASS: Radix is too big: roundoff problems
TEST: Radix is not as good as 2 or 10
PASS: Radix is not as good as 2 or 10
TEST: (1-U1)-1/2 < 1/2 is FALSE, prog. fails?
ERROR: Severity: FAILURE: (1-U1)-1/2 < 1/2 is FALSE, prog. fails?.
PASS: (1-U1)-1/2 < 1/2 is FALSE, prog. fails?
TEST: Comparison is fuzzy,X=1 but X-1/2-1/2 != 0
PASS: Comparison is fuzzy,X=1 but X-1/2-1/2 != 0
The number of significant digits of the Radix is 64.000000 .
TEST: Precision worse than 5 decimal figures
PASS: Precision worse than 5 decimal figures
TEST: Subtraction is not normalized X=Y,X+Z != Y+Z!
PASS: Subtraction is not normalized X=Y,X+Z != Y+Z!
Subtraction appears to be normalized, as it should be.
Checking for guard digit in *, /, and -.
TEST: * gets too many final digits wrong.
PASS: * gets too many final digits wrong.
TEST: Division lacks a Guard Digit, so error can exceed 1 ulp
or 1/3 and 3/9 and 9/27 may disagree
PASS: Division lacks a Guard Digit, so error can exceed 1 ulp
TEST: Computed value of 1/1.000..1 >= 1
PASS: Computed value of 1/1.000..1 >= 1
TEST: * and/or / gets too many last digits wrong
PASS: * and/or / gets too many last digits wrong
TEST: - lacks Guard Digit, so cancellation is obscured
ERROR: Severity: SERIOUS DEFECT: - lacks Guard Digit, so cancellation
is obscured.
PASS: - lacks Guard Digit, so cancellation is obscured
Checking rounding on multiply, divide and add/subtract.
TEST: X * (1/X) differs from 1
PASS: X * (1/X) differs from 1
* is neither chopped nor correctly rounded.
/ is neither chopped nor correctly rounded.
TEST: Radix * ( 1 / Radix ) differs from 1
PASS: Radix * ( 1 / Radix ) differs from 1
TEST: Incomplete carry-propagation in Addition
PASS: Incomplete carry-propagation in Addition
Addition/Subtraction neither rounds nor chops.
Sticky bit used incorrectly or not at all.
TEST: lack(s) of guard digits or failure(s) to correctly round or chop
(noted above) count as one flaw in the final tally below
ERROR: Severity: FLAW: lack(s) of guard digits or failure(s) to
(noted above) count as one flaw in the final tally below.
PASS: lack(s) of guard digits or failure(s) to correctly round or chop
Does Multiplication commute? Testing on 20 random pairs.
No failures found in 20 integer pairs.
Running test of square root(x).
TEST: Square root of 0.0, -0.0 or 1.0 wrong
PASS: Square root of 0.0, -0.0 or 1.0 wrong
Testing if sqrt(X * X) == X for 20 Integers X.
Test for sqrt monotonicity.
ERROR: Severity: DEFECT: sqrt(X) is non-monotonic for X near
2.0000000e+00 .
Testing whether sqrt is rounded or chopped.
Square root is neither chopped nor correctly rounded.
Observed errors run from -5.5000000e+00 to 5.0000000e-01 ulps.
TEST: sqrt gets too many last digits wrong
ERROR: Severity: SERIOUS DEFECT: sqrt gets too many last digits wrong.
PASS: sqrt gets too many last digits wrong
Testing powers Z^i for small Integers Z and i.
ERROR: Severity: DEFECT: computing
(1.30000000000000000e+01) ^ (1.70000000000000000e+01)
yielded 8.65041591938133811e+18;
which compared unequal to correct 8.65041591938133914e+18 ;
they differ by -1.02400000000000000e+03 .
Errors like this may invalidate financial calculations
involving interest rates.
Similar discrepancies have occurred 5 times.
Seeking Underflow thresholds UfThold and E0.
Smallest strictly positive number found is E0 = 0 .
ERROR: Severity: FAILURE: Either accuracy deteriorates as numbers
approach a threshold = 0.00000000000000000e+00
coming down from 0.00000000000000000e+00
or else multiplication gets too many last digits wrong.
The Underflow threshold is 0.00000000000000000e+00, below which
calculation may suffer larger Relative error than merely roundoff.
Since underflow occurs below the threshold
UfThold = (2.00000000000000000e+00) ^ (-inf)
only underflow should afflict the expression
(2.00000000000000000e+00) ^ (-inf);
actually calculating yields: 0.00000000000000000e+00 .
This computed value is O.K.
Testing X^((X + 1) / (X - 1)) vs. exp(2) = 7.38905609893065041e+00 as X
-> 1.
ERROR: Severity: DEFECT: Calculated 1.00000000000000000e+00 for
(1 + (0.00000000000000000e+00) ^ (inf);
differs from correct value by -6.38905609893065041e+00 .
This much error may spoil financial
calculations involving tiny interest rates.
Testing powers Z^Q at four nearly extreme values.
... no discrepancies found.
Searching for Overflow threshold:
This may generate an error.
Can `Z = -Y' overflow?
Trying it on Y = -inf .
finds a ERROR: Severity: FLAW: -(-Y) differs from Y.
Overflow threshold is V = -inf .
Overflow saturates at V0 = inf .
No Overflow should be signaled for V * 1 = -inf
nor for V / 1 = -inf .
Any overflow signal separating this * from the one
above is a DEFECT.
ERROR: Severity: FAILURE: Comparisons involving +--inf, +-inf
and +-0 are confused by Overflow.
ERROR: Severity: SERIOUS DEFECT: X / X differs from 1 when X = -inf
instead, X / X - 1/2 - 1/2 = nan .
What message and/or values does Division by Zero produce?
Trying to compute 1 / 0 produces ... inf .
Trying to compute 0 / 0 produces ... nan .
The number of FAILUREs encountered = 3.
The number of SERIOUS DEFECTs discovered = 4.
The number of DEFECTs discovered = 3.
The number of FLAWs discovered = 2.
The arithmetic diagnosed has unacceptable Serious Defects.
Potentially fatal FAILURE may have spoiled this program's subsequent
diagnoses.
END OF TEST.
*** END OF TEST PARANOIA ***
EXECUTIVE SHUTDOWN! Any key to reboot...
URL: <http://lists.rtems.org/pipermail/users/attachments/20141211/b69ca94d/attachment-0001.html>
