Compilation error
Rui Pedro Caldeira
rpcaldeira at outlook.com
Thu Dec 11 20:46:57 UTC 2014
Hello again Gedare, and thank you for the warm welcome :)
I'm sorry if i did not put up this information previously but here it comes:
- OS: Xubuntu 14.04
- fc38848 at Clevo:~$ uname -a
Linux Clevo 3.13.0-43-generic #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC 2014
x86_64 x86_64 x86_64 GNU/Linux
- Toolchain: RTEMS Source Builder - Command:
../source-builder/sb-set-builder --log=l-sparc.txt
--prefix=/opt/RTEMS/4.10.2_tools/ 4.10/rtems-sparc
- Configure command-line: ../4.10.2_src/configure
--target=sparc-rtems4.10.2 --enable-rtemsbsp=leon3 --enable-posix
--enable-tests=samples --disable-itron --disable-networking --disable-cxx
--dis --disable-testsle-rtemsdebug
- Configure log: http://pastebin.com/duHk618n
- First time make log: http://pastebin.com/UiDYy5Js
Thanks for all your help really :)
Rui
Cumprimentos,
Rui Pedro Caldeira
On Thu, Dec 11, 2014 at 8:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hello and Welcome!
> Some more information is needed. What toolchain are you using? Are you
> using Gaisler's RCC? Or the RPMs? Or did you build your own, if so did
> you use RTEMS Source Builder to help? What host distro are you on?
> (Sometimes helps to know.)
> How do you build RTEMS? What 'configure' command line? Were there any
> errors during 'configure'?
> The log you posted looks like you already attempted 'make' before, and
> it failed. What was the output from the first try?
> -Gedare
> On Thu, Dec 11, 2014 at 2:09 PM, Rui Pedro Caldeira
> <rpcaldeira at outlook.com> wrote:
> > Hey guys! I'm new here and to RTEMS. I swear i tried to find this
> elsewhere
> > before bothering you.
> > I'm compiling RTEMS 4.10 for sparc leon3
> > and i get the following complilation error:
> > fc38848 at Clevo:/opt/RTEMS/4.10.2_build$ make all install
> > Making all in make
> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/make'
> > make[1]: Nothing to be done for `all'.
> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/make'
> > Making all in tools/build
> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/tools/build'
> > make all-am
> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/tools/build'
> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/build'
> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/build'
> > Making all in tools/cpu
> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/tools/cpu'
> > Making all in generic
> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/tools/cpu/generic'
> > make[2]: Nothing to be done for `all'.
> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu/generic'
> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/tools/cpu'
> > make[2]: Nothing to be done for `all-am'.
> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu'
> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu'
> > Making all in sparc-rtems4.10.2/c
> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c'
> > Making all in .
> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c'
> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c'
> > Making all in leon3
> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3'
> > Making all in .
> > make[3]: Entering directory
> > make[3]: Nothing to be done for `all-am'.
> > make[3]: Leaving directory
> > Making all in cpukit
> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit'
> > make all-recursive
> > make[4]: Entering directory
> > Making all in .
> > make[5]: Entering directory
> > make[5]: Leaving directory
> > Making all in score
> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score'
> > Making all in cpu
> > make[6]: Entering directory
> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score/cpu'
> > Making all in sparc
> > make[7]: Entering directory
> `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score/cpu/sparc'
> > rm -f libscorecpu.a
> > no cru libscorecpu.a libscorecpu_a-cpu.o libscorecpu_a-cpu_asm.o
> > /bin/bash: no: command not found
> > make[7]: *** [libscorecpu.a] Error 127
> > make[7]: Leaving directory
> > make[6]: *** [all-recursive] Error 1
> > make[6]: Leaving directory
> > make[5]: *** [all-recursive] Error 1
> > make[4]: *** [all-recursive] Error 1
> > make[4]: Leaving directory
> > make[3]: *** [all] Error 2
> > make[2]: *** [all-recursive] Error 1
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c'
> > make: *** [all-recursive] Error 1
> > Anyone can help me?
> > Best Regards,
> > Rui Pedro Caldeira
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20141211/1866bfe2/attachment-0001.html>
