Source builder kinks
Steve B
sbattazzo at gmail.com
Fri Dec 12 18:44:03 UTC 2014
Hi Chris,
I can give that a shot some time soonish and let you know.
Since zlib is a compression/decompression library I would like to guess
that it's not super critical for rtems build environment, but taking away
that dependency still doesn't solve the ncurses5-dev or python headers
ones, so I'd rather think of a good way to check for those in the sb-check.
Or if we can figure out how to ensure that hash checking thing actually
works so the builder doesn't start from the beginning each time; then just
having to install those packages and pick up where the builder last left
off would have been much less of an inconvenience!
Steve
On Thu, Dec 11, 2014 at 2:36 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 12/12/2014 7:12 am, Joel Sherrill wrote:
>> On 12/11/2014 2:05 PM, Steve B wrote:
>>> Hello all,
>>> Using the source builder to build something this morning I found that
>>> the zlib was missing on Linux Mint (which is effectively Ubuntu). I
>>> also run into errors later on because of missing ncurses-devel and
>>> python2.7-dev (I assume that's the right package because python is
>>> there by default but the error said it wasn't). Seems like the source
>>> builder starts from the beginning taking another hour each time though
>>> some of the big intermediate steps were already compiled.
> It would be nice if gcc actually check and stopped earlier but it does not.
>>> Maybe these could get added to the sb-check script so they're
>>> identified before running into build errors? And, is there any way to
>>> invoke the source builder without re-doing things that have already
>>> successfully compiled?
>>> Chris and I have had this discussion so I will give a quick answer.
>> sb-check knows how to check for missing commands not missing libraries.
>> We haven't figured out a good solution to how to generally probe.
>> If you have ideas, we are listening. :)
> Steve,
> What happens if --with-system-zlib is removed, ie the same as a mingw32
> build :
> https://devel.rtems.org/browser/rtems-source-builder/
> source-builder/config/gcc-common-1.cfg#L122
> ? Are you able to test this for me ?
> I am happy to make the change so this dependency goes away. It seems to be
> the only one that comes up all the time.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20141212/87f58113/attachment-0001.html>
