msdos_format - deadlock
Wed Dec 17 13:12:58 UTC 2014
On 16/12/14 15:12, Federico Garcia Cruz wrote:
> I'm running rtems 4.10 on a mbed board (LPC1768 ARM micro controller),
The Cortex-M is not supported in RTEMS 4.10.  Do you really use RTEMS 4.10?
> and I'm trying to use the dos filesystem with a nvdisk. I can register
> the device driver correctly but when I try to format the disk it never
> returns from the format function.
> It seems to be a deadlock in rtems_bdbuf_get function.
> Could you give a hand please?
I would first test that your setup works with plain block read/write
transfers.  What do you mean with deadlock?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
