msdos_format - deadlock
Fri Dec 19 07:00:56 UTC 2014
On 18/12/14 19:29, Federico Garcia Cruz wrote:
> The bfbuf config looks like:
> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS  0
> #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS       5
> #define CONFIGURE_SWAPOUT_TASK_PRIORITY        3
> #define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE 1024
> #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE 256
> #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 512
> #define CONFIGURE_BDBUF_TASK_STACK_SIZE 512
> #define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY 3
Are you sure that the task stack size is all right?  You have only a 2
block buffer (CONFIGURE_BDBUF_CACHE_MEMORY_SIZE) which doesn't really
make sense.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
