C++ Constructor Initialization Failure for Cortex-A8
    Sebastian Huber
    Mon Dec  1 08:14:52 UTC 2014
Hello,
this test works fine with the latest RTEMS on arm/realview_pbx_a9_qemu,
so I guess this is a BSP specific problem:
realview_pbx_a9_qemu -i
./build/arm-rtems4.11-realview_pbx_a9_qemu/cxx/cxx_throw/cxx_throw.exe
qemu-system-arm is /opt/qemu/bin/qemu-system-arm
Hey I'm in base class constructor number 1 for 0x201dc4.
Hey I'm in base class constructor number 2 for 0x201dcc.
Hey I'm in derived class constructor number 3 for 0x201dcc.
*** CONSTRUCTOR/DESTRUCTOR TEST ***
Hey I'm in base class constructor number 4 for 0x20d304.
Hey I'm in base class constructor number 5 for 0x20d2fc.
Hey I'm in base class constructor number 6 for 0x20d2f4.
Hey I'm in base class constructor number 7 for 0x20d2ec.
Hey I'm in derived class constructor number 8 for 0x20d2ec.
Testing a C++ I/O stream
before try block
Got it: Raising this
catch got called, exception handling worked !!!
Hey I'm in derived class destructor number 8 for 0x20d2ec.
Derived class - Instantiation order 8
Hey I'm in base class destructor number 7 for 0x20d2ec.
Hey I'm in base class destructor number 6 for 0x20d2f4.
Instantiation order 6
Hey I'm in base class destructor number 5 for 0x20d2fc.
Instantiation order 5
Hey I'm in base class destructor number 4 for 0x20d304.
*** END OF CONSTRUCTOR/DESTRUCTOR TEST ***
Hey I'm in derived class destructor number 3 for 0x201dcc.
Derived class - Instantiation order 3
Hey I'm in base class destructor number 2 for 0x201dcc.
Hey I'm in base class destructor number 1 for 0x201dc4.
Instantiation order 1
On 01/12/14 08:59, Thomas Kim wrote:
> Dear Sebastian,
> I tested cxx_throw.exe. in my case, I successed to build cxx_throw.exe.
> After run cxx_throw.exe, my problem is occurred.
> Best Regards,
> Thomas Kim
> 2014-12-01 16:45 GMT+09:00 Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>:
>     Hello,
>     what is the name of the failing test?  Is this cxx_throw.exe?
>     There seems to be also a build problem for the examples-v2:
>     Waf: Entering directory
>     `/home/sh/git-rtems-examples-v2/build/arm-rtems4.11-realview_pbx_a9_qemu'
>     [  4/116] FilesystemImage:  -> file_io/crc/FilesystemImage
>     [  5/116] bin2c: file_io/crc/FilesystemImage ->
>     file_io/crc/FilesystemImage.c file_io/crc/FilesystemImage.h
>     [ 22/116] c: file_io/crc/FilesystemImage.c ->
>     build/arm-rtems4.11-realview_pbx_a9_qemu/file_io/crc/FilesystemImage.c.2.o
>     [115/116] rtrace:
>     build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/test.c.2.o
>     build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/hello-deep.texe
>     [115/116] cprogram:
>     build/arm-rtems4.11-realview_pbx_a9_qemu/file_io/crc/init.c.2.o
>     build/arm-rtems4.11-realview_pbx_a9_qemu/file_io/crc/crc_32.c.2.o
>     -> build/arm-rtems4.11-realview_pbx_a9_qemu/file_io/crc/crc.exe
>     [116/116] rtrace:
>     build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/test.c.1.o
>     build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/both_hello.texe
>     /opt/rtems-4.11/bin/arm-rtems4.11-gcc:  hello-test.o: In function
>     `__wrap_Init':
>     /home/sh/git-rtems-examples-v2/build/arm-rtems4.11-realview_pbx_a9_qemu/
>     hello-test.c:70: undefined reference to `Init'
>     /opt/rtems-4.11/bin/arm-rtems4.11-gcc: collect2: error: ld
>     returned 1 exit status
>     error: linking: Linker error
>     /opt/rtems-4.11/bin/arm-rtems4.11-gcc:  hello-deep.o: In function
>     `__wrap_Init':
>     hello-deep.c:78: undefined reference to `Init'
>     Waf: Leaving directory
>     Build failed
>      -> task in 'both_hello.texe' failed (exit status 10):
>             {task 17773776: rtrace test.c.1.o -> both_hello.texe}
>     ['/opt/rtems-4.11/bin/rtems-tld', '-W hello-test', '-C',
>     '../../hello/both_hello/hello.ini', '-r', '/opt/rtems-4.11', '-B',
>     'arm/realview_pbx_a9_qemu', '-c',
>     '/opt/rtems-4.11/bin/arm-rtems4.11-gcc', '-l',
>     '/opt/rtems-4.11/bin/arm-rtems4.11-gcc', '--',
>     'hello/both_hello/test.c.1.o', '-qrtems',
>     '-B/opt/rtems-4.11/arm-rtems4.11/lib/',
>     '-B/opt/rtems-4.11/arm-rtems4.11/realview_pbx_a9_qemu/lib/',
>     '--specs', 'bsp_specs', '-march=armv7-a', '-march=armv7-a',
>     '-mthumb', '-mthumb', '-mfpu=neon', '-mfpu=neon',
>     '-mfloat-abi=hard', '-mfloat-abi=hard', '-mtune=cortex-a9',
>     '-mtune=cortex-a9', '-o',
>     '/home/sh/git-rtems-examples-v2/build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/both_hello.texe',
>     '-Wl,-Bstatic']
>      -> task in 'hello-deep.texe' failed (exit status 10):
>             {task 17774032: rtrace test.c.2.o -> hello-deep.texe}
>     ['/opt/rtems-4.11/bin/rtems-tld', '-W hello-deep', '-C',
>     '../../hello/both_hello/hello-deep.ini', '-r', '/opt/rtems-4.11',
>     '-B', 'arm/realview_pbx_a9_qemu', '-c',
>     'hello/both_hello/test.c.2.o', '-qrtems',
>     '/home/sh/git-rtems-examples-v2/build/arm-rtems4.11-realview_pbx_a9_qemu/hello/both_hello/hello-deep.texe',
>     '-Wl,-Bstatic']
>     On 01/12/14 05:26, Thomas Kim wrote:
>>     Dear Sir,
>>     I am testing cxx example including C++ global constructor in
>>     example-v2 on Cortex-A8 based board.
>>     As I remembered in csae of using cxx example on Sparc SIS, I
>>     resolved this after removing below options according to your comment.
>>       CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
>>       LDFLAGS = -Wl,--gc-sections
>>     But, when I test same cxx example on ARM Cortex-A8 board, I have
>>     similar problem as like below;
>>     terminate called after throwing an instance of
>>     '__gnu_cxx::__concurrence_lock_error'
>>       what():  __gnu_cxx::__concurrence_lock_error
>>     At this time, I used below config options for Cortex-A8.
>>     CPU_CFLAGS = -march=armv7-a -mtune=cortex-a8 -mfpu=neon
>>     -mfloat-abi=softfp
>>     CFLAGS_OPTIMIZE_V ?= -O2 -g
>>     also, I am using RSB GCC 4.8.2 as like below;
>>     Target: arm-rtems4.11
>>     Configured with: ../gcc-4.8.2/configure --prefix=/opt/rtems-4.11
>>     --bindir=/opt/rtems-4.11/bin --exec_prefix=/opt/rtems-4.11
>>     --includedir=/opt/rtems-4.11/include --libdir=/opt/rtems-4.11/lib
>>     --libexecdir=/opt/rtems-4.11/libexec
>>     --mandir=/opt/rtems-4.11/share/man
>>     --infodir=/opt/rtems-4.11/share/info
>>     --datadir=/opt/rtems-4.11/share --build=i686-linux-gnu
>>     --host=i686-linux-gnu --target=arm-rtems4.11
>>     --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose
>>     --with-newlib --with-system-zlib --disable-nls
>>     --without-included-gettext --disable-win32-registry
>>     --enable-version-specific-runtime-libs --disable-lto
>>     --enable-newlib-io-c99-formats --enable-newlib-iconv
>>     --enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
>>     --enable-threads --disable-plugin --enable-obsolete
>>     --enable-languages=c,c++
>>     Thread model: posix
>>     gcc version 4.8.2 20131016 (RTEMS
>>     4.11-RSB-40d25dc8fe6da6b93b295d9b42632c1d3338a97a-1,gcc-4.8.2/newlib-2.1.0)
>>     (GCC)
>>     Please let me  know how to resolve this problem ?
>>     Thomas Kim
>>     _______________________________________________
>>     users mailing list
>>     users at rtems.org  <mailto:users at rtems.org>
>>     http://lists.rtems.org/mailman/listinfo/users
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  :sebastian.huber at embedded-brains.de  <mailto:sebastian.huber at embedded-brains.de>
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20141201/9080d11d/attachment-0002.html>
