Context switching for VFP registers on Cortex-A8 board.
Thomas Kim
thomas73.kim at gmail.com
Tue Dec 2 10:38:34 UTC 2014
Dear Sebastian,
I used lastest RTEMS source on https://github.com/RTEMS/rtems.
Is there initialization code(start.S) for handling SCTLR.A bit on current
source tree ?
Best Regards,
Thomas Kim
2014-12-02 19:27 GMT+09:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> Hello,
> you use a BSP that is not included in the main RTEMS sources, so I can
> only guess.
> On 02/12/14 11:16, Thomas Kim wrote:
>> Dear Sir.
>> I completed to port RTEMS on Cortex-A8 board using below option.
>> CPU_CFLAGS = -march=armv7-a -mtune=cortex-a8 -mfpu=neon
>> -mfloat-abi=softfp
>> At this time, RTEMS sample example(ticker.exe) is working very well.
>> Because there is a problem for executing C++ exception example using
>> "-mfloat-abi=softfp", I changed below option.
>> CPU_CFLAGS = -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=hard
>> After I rebuild RTEMS using "-mfloat-abi=hard", I am tring to test both
>> ticker.exe and cxx_throw.exe.
>> But, both examples are crashed in mount() function of
>> rtems_filesystem_initialize().
>> In detailly, memcpy() of alloc_mount_table_entry() is called, exception
>> is ocurred.
> There are many exceptions and some provide extra information, so
> "exception is occurred" is a very vague description.
> You probably use the wrong memory attributes. Make sure misaligned memory
> access is possible. See SCTLR.A bit (ARM_CP15_CTRL_A).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20141202/50198d1e/attachment-0002.html>
