Compilation error
Cláudio Silva claudiodcsilva at gmail.com
Fri Dec 12 13:41:21 UTC 2014
Hi Rui,
I guess the initial problem is that you are configuring RTEMS with the
wrong target; your target should be "sparc-rtems4.10" and not
"sparc-rtems4.10.2". This target triplet is used during the configure
process to find the cross-compilation toolchain. In your case, configure is
not able to find the tools (line 703 of your configure log) and it is
trying to use no, as in *no* sparc-rtems4.10-ar found, as the ar tool.
Nonetheless, I don't know why configure is not existing with an error
condition.
If you correct the target all should proceed correctly.
Cumprimentos,
Cláudio
On Fri Dec 12 2014 at 12:40:09 Rui Pedro Caldeira <rpcaldeira at outlook.com>
wrote:
> Hello to all!
> I just solved the problem and wanted to state the solution for the record.
> Since the error was occurring in the
> */opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score/cpu/sparc*
> directory I've decided to go and take a look at its *Makefile*. My search
> started my looking for the "cru" keyword. I've found the line 124: ARFLAGS
> = cru. Then I've searched for the "no" keyword and found the line 233: AR =
> no. My thought was that no was an supposed alias for the archiver (AR)
> utility. After that was easy creating a "no" simlink to the
> "sparc-rtems4.10-ar" in the RTEMS tools directory *(ln -s
> ./sparc-rtems4.10-ar no)* and the compilation was without a problem after
> that.
> Thanks for all your help everyone :)
> Regards and Happy Holidays,
> Rui
> Cumprimentos,
> Rui Pedro Caldeira
> On Thu, Dec 11, 2014 at 8:46 PM, Rui Pedro Caldeira <
> rpcaldeira at outlook.com> wrote:
>> Hello again Gedare, and thank you for the warm welcome :)
>> I'm sorry if i did not put up this information previously but here it
>> comes:
>>    - OS: Xubuntu 14.04
>>    - fc38848 at Clevo:~$ uname -a
>>    Linux Clevo 3.13.0-43-generic #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC
>>    2014 x86_64 x86_64 x86_64 GNU/Linux
>>    - Toolchain: RTEMS Source Builder - Command: ../source-builder/sb-set-builder
>>    --log=l-sparc.txt --prefix=/opt/RTEMS/4.10.2_tools/ 4.10/rtems-sparc
>>    - Configure command-line: ../4.10.2_src/configure
>>    --target=sparc-rtems4.10.2 --enable-rtemsbsp=leon3 --enable-posix
>>    --enable-tests=samples --disable-itron --disable-networking --disable-cxx
>>    --dis --disable-testsle-rtemsdebug
>>    - Configure log: http://pastebin.com/duHk618n
>>    - First time make log: http://pastebin.com/UiDYy5Js
>> Thanks for all your help really :)
>> Rui
>> Cumprimentos,
>> Rui Pedro Caldeira
>> On Thu, Dec 11, 2014 at 8:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hello and Welcome!
>>> Some more information is needed. What toolchain are you using? Are you
>>> using Gaisler's RCC? Or the RPMs? Or did you build your own, if so did
>>> you use RTEMS Source Builder to help? What host distro are you on?
>>> (Sometimes helps to know.)
>>> How do you build RTEMS? What 'configure' command line? Were there any
>>> errors during 'configure'?
>>> The log you posted looks like you already attempted 'make' before, and
>>> it failed. What was the output from the first try?
>>> -Gedare
>>> On Thu, Dec 11, 2014 at 2:09 PM, Rui Pedro Caldeira
>>> <rpcaldeira at outlook.com> wrote:
>>> > Hey guys! I'm new here and to RTEMS. I swear i tried to find this
>>> elsewhere
>>> > before bothering you.
>>> > I'm compiling RTEMS 4.10 for sparc leon3
>>> > and i get the following complilation error:
>>> > fc38848 at Clevo:/opt/RTEMS/4.10.2_build$ make all install
>>> > Making all in make
>>> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/make'
>>> > make[1]: Nothing to be done for `all'.
>>> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/make'
>>> > Making all in tools/build
>>> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/tools/build'
>>> > make  all-am
>>> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/tools/build'
>>> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/build'
>>> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/build'
>>> > Making all in tools/cpu
>>> > make[1]: Entering directory `/opt/RTEMS/4.10.2_build/tools/cpu'
>>> > Making all in generic
>>> tools/cpu/generic'
>>> > make[2]: Nothing to be done for `all'.
>>> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu/generic'
>>> > make[2]: Entering directory `/opt/RTEMS/4.10.2_build/tools/cpu'
>>> > make[2]: Nothing to be done for `all-am'.
>>> > make[2]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu'
>>> > make[1]: Leaving directory `/opt/RTEMS/4.10.2_build/tools/cpu'
>>> > Making all in sparc-rtems4.10.2/c
>>> sparc-rtems4.10.2/c'
>>> > Making all in .
>>> > Making all in leon3
>>> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3'
>>> > Making all in .
>>> > make[3]: Entering directory
>>> > make[3]: Nothing to be done for `all-am'.
>>> > make[3]: Leaving directory
>>> > Making all in cpukit
>>> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit'
>>> > make  all-recursive
>>> > make[4]: Entering directory
>>> > Making all in .
>>> > make[5]: Entering directory
>>> > make[5]: Leaving directory
>>> > Making all in score
>>> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score'
>>> > Making all in cpu
>>> > make[6]: Entering directory
>>> > `/opt/RTEMS/4.10.2_build/sparc-rtems4.10.2/c/leon3/cpukit/score/cpu'
>>> > Making all in sparc
>>> > make[7]: Entering directory
>>> cpukit/score/cpu/sparc'
>>> > rm -f libscorecpu.a
>>> > no cru libscorecpu.a libscorecpu_a-cpu.o libscorecpu_a-cpu_asm.o
>>> > /bin/bash: no: command not found
>>> > make[7]: *** [libscorecpu.a] Error 127
>>> > make[7]: Leaving directory
>>> > make[6]: *** [all-recursive] Error 1
>>> > make[6]: Leaving directory
>>> > make[5]: *** [all-recursive] Error 1
>>> > make[4]: *** [all-recursive] Error 1
>>> > make[4]: Leaving directory
>>> > make[3]: *** [all] Error 2
>>> > make[2]: *** [all-recursive] Error 1
>>> > make[1]: *** [all-recursive] Error 1
>>> > make: *** [all-recursive] Error 1
>>> > Anyone can help me?
>>> > Best Regards,
>>> > Rui Pedro Caldeira
>>> > _______________________________________________
>>> > users mailing list
>>> > users at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20141212/d98103af/attachment-0002.html>
