Including 3rd party library headers?
James Fitzsimons
james.fitzsimons at gmail.com
Sun Feb 2 09:47:42 UTC 2014
Hi all,
Thanks for all the advice so far.
I spent quite a bit of time the other night working my way through all the
RTEMS makefiles trying to understand how they all hang together.
I tried giving CPU_CFLAGS ago but that didn't work. So, after another look
at the makefiles I tried CFLAGS_FOR_TARGET which was successful!
I'm guessing it's ok to abuse that variable like this?
Cheers,
James
On 31 January 2014 22:06, Ralf Kirchner <ralf.kirchner at embedded-brains.de>wrote:
> Hi James,
> For my current target CFLAGS get composed and passed to the compiler in
> bsp.mk which gets included over several stages from the application
> Makefile.
> I suppose for your BSP it will be similar.
> In my case the relevant part of the file looks like:
> include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP).cfg
> DEPFLAGS = -MT $@ -MD -MP -MF $(basename $@).d
> SYSFLAGS = -B $(PROJECT_LIB) -specs bsp_specs -qrtems
> WARNFLAGS = -Wall -Wextra -Wformat=2 -Wcast-qual -Wconversion
> -Wno-unused-parameter
> OPTFLAGS = $(CFLAGS_OPTIMIZE_V)
> CFLAGS = $(DEPFLAGS) $(SYSFLAGS) $(WARNFLAGS) $(CPU_CFLAGS) $(OPTFLAGS)
> CXXFLAGS = $(DEPFLAGS) $(SYSFLAGS) $(WARNFLAGS) $(CPU_CFLAGS) $(OPTFLAGS)
> LINKFLAGS = $(SYSFLAGS) $(CPU_CFLAGS) $(LDFLAGS) $(OPTFLAGS)
> ASFLAGS = $(CPU_CFLAGS)
> CCLINK = $(CC) $(LINKFLAGS) -Wl,-Map,$(basename $@).map
> CXXLINK = $(CXX) $(LINKFLAGS) -Wl,-Map,$(basename $@).map
> $(BUILDDIR)/%.o: %.c
> $(CC) $(CPPFLAGS) $(CFLAGS) -c $< -o $@
> Thus apending your include files to CFLAGS won't work. I am not sure if
> that would work but you might give CPU_CFLAGS a try instead.
> Am 30.01.2014 11:19, schrieb James Fitzsimons:
> > I tried CFLAGS as suggested and it seems to be completely ignored. My
> > application Makefile now looks like this:
> > PGM=${ARCH}/rtems-hello.exe
> > # optional managers required
> > MANAGERS=all
> > # C source names
> > CSRCS = rtems-hello.c
> > COBJS = $(CSRCS:%.c=${ARCH}/%.o)
> > CFLAGS += -I/home/james/Projects/development/motorobots/include
> > MOTOROBOTS_LIBS = /opt/motorobots/68332/lib
> > #LD_PATHS +=
> > LD_LIBS += $(MOTOROBOTS_LIBS)/liblcd.a $(MOTOROBOTS_LIBS)/libled.a
> > include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> > include $(RTEMS_CUSTOM)
> > include $(PROJECT_ROOT)/make/leaf.cfg
> > OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
> > all: ${ARCH} $(PGM)
> > $(PGM): $(OBJS) ${LINK_FILES}
> > $(make-exe)
> > and running make looks like:
> > hello$ make
> > test -d o-optimize || mkdir o-optimize
> > m68k-rtems4.10-gcc --pipe
> -B/home/james/Projects/development/rtems/rtems-mrm332/m68k-rtems4.10/mrm332/lib/
> > -specs bsp_specs -qrtems -g -Wall -O2 -g -fomit-frame-pointer -g
> > -mcpu=cpu32 -c -o o-optimize/rtems-hello.o rtems-hello.c
> > rtems-hello.c:6:27: error: 68332/mrm/led.h: No such file or directory
> > rtems-hello.c:7:27: error: 68332/mrm/lcd.h: No such file or directory
> > As you can see the include path doesn't appear in the gcc command.
> > I've read the make/README and can't see anything relavant in there. Am I
> > missing something really obvious here?
> > Thanks for any help you can provide!
> > James
> > On 30 January 2014 13:38, James Fitzsimons <james.fitzsimons at gmail.com
> > <mailto:james.fitzsimons at gmail.com>> wrote:
> > Thanks very much guys,
> > I'm thought I'd tried CFLAGS, but I obviously didn't have something
> > quite right so I'll give it another shot.
> > I'll definitely look into Eclipse - I've used it before for C/C++
> > stuff and found it excellent. I'm trying to start out pretty vanilla
> > with RTEMS just so I get a really good handle on how the whole build
> > process works (there are a LOT of makefiles to understand) as I've
> > found with other tools that an IDE can often make things nice and
> > easy until it goes wrong, and if you don't understand what it's
> > doing under the hood you are all of a sudden in very deep water.
> > Cheers!
> > James
> > On 30 January 2014 12:53, Simon Williams <williamssimonp at gmail.com
> > <mailto:williamssimonp at gmail.com>> wrote:
> > Ah, -I and CFLAGS it is then. That'll teach me to read posts
> > properly and not just skim them! :-)
> > I started using Eclipse for Java, but I moved to using Netbeans
> > as I prefer it, but Eclipse with CDT is a grest C/C++ IDE and
> > the RTEMS plug in makes RTEMS development more productive than
> > vi. I don't really know of an alternative iif you want an IDE
> > for RTEMS, but that may be just because I've not looked.
> > Regards
> > Simon
> > On 29 Jan 2014 23:36, "Nick Withers" <nick.withers at anu.edu.au
> > <mailto:nick.withers at anu.edu.au>> wrote:
> > On Wed, 2014-01-29 at 23:31 +0000, Simon Williams wrote:
> > > Wouldn't thst be -L for the lbrary path? The -l option is
> > usef to
> > > specify a library.
> > > Also, linker flags are usually in LDFLAGS, CFLAGS is for
> > compiler
> > > flags. It does of course depend on your Makefile.
> > It's include paths he's after, which are for the compiler.
> > > I would recommend Eclipse. It won't do everything for you,
> > but it can
> > > help by pointing the way!
> > I've heard a lot of good things about Eclipse. I've got a
> > personal peeve
> > against Java and that's really all that's kept me from
> > trying it!
> > > Regards
> > > Simon
> > > On 29 Jan 2014 22:18, "Nick Withers"
> > <nick.withers at anu.edu.au <mailto:nick.withers at anu.edu.au>>
> > wrote:
> > > On Wed, 2014-01-29 at 22:29 +1300, James
> > Fitzsimons wrote:
> > > > Thanks Andrei,
> > > > I'm using a very plain vanilla environment at
> > the moment.
> > > Ubuntu 13.10
> > > > with tool chain built using rtems source builder.
> > > > I'm using the template makefile for my test
> > application, and
> > > am just
> > > > running make directly from bash.
> > > > No IDE or fancy build environment yet!
> > > I'd've said the RTEMS'provided Makefiles (there
> > are a number
> > > of them,
> > > chained together) are pretty fancy... But then, I
> > have trouble
> > > with just
> > > one Makefile :-P
> > > Anyway, try:
> > > CFLAGS+=-I/bam/headers
> > > > Cheers,
> > > > James
> > > > On 29 January 2014 17:01, Andrei Chichak
> > <groups at chichak.ca <mailto:groups at chichak.ca>>
> > > wrote:
> > > > I believe what Sebastian is referring to
> > is the
> > > environment
> > > > that you are using for your compiles. In
> > my case, I
> > > am using a
> > > > Mac and Eclipse, I set <C/C++
> > Build><Settings><Tool
> > > > Settings><RTEMS C
> > Compiler><Preprocessor><Include
> > > Paths (-I)>.
> > > > Your milage will vary, but if you tell
> > us what you
> > > are
> > > > driving, there may be someone here that
> > can help.
> > > > Andrei
> > > > On 2014-January-28, at 2:11 PM, James
> > Fitzsimons
> > > > > Hi Sebastian,
> > > > > Thanks for your reply.
> > > > > Ideally I was hoping to us the -I
> > option to
> > > specify the
> > > > header file location, I just can't quite
> > figure out
> > > where to
> > > > add that into the RTEMS makefile
> > structure. Looking
> > > at the
> > > > make/README I can see a good example of
> > how to link
> > > in other
> > > > libraries using LD_LIBS, but there's
> > nothing about
> > > including
> > > > other header files.
> > > > > Apologies if I am missing something
> > obvious!
> > Nick Withers
> > Embedded Systems Programmer
> > Department of Nuclear Physics, Research School of Physics
> > and Engineering
> > The Australian National University (CRICOS: 00120C)
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Embedded Brains GmbH
> Ralf Kirchner Dornierstr. 4
> D-82178 Puchheim Germany
> email: ralf.kirchner at embedded-brains.de
> Phone: +49-89-18 94 741-17
> Fax: +49-89-18 94 741-08
URL: <http://lists.rtems.org/pipermail/users/attachments/20140202/7476b471/attachment.html>
