Downloading/Uploading RTEMS app to mcp750
Noble N. Nkwocha
Noble.N.Nkwocha at nasa.gov
Wed Feb 19 16:56:09 UTC 2014
Thank you.
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
(505) 238-5927 Cellular (Evenings, Nights and Weekends ONLY)
Noble.N.Nkwocha at NASA.Gov<mailto:Noble.N.Nkwocha at nasa.gov>
From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] On Behalf Of Greg Menke
Sent: Wednesday, February 19, 2014 11:52 AM
To: rtems-users at rtems.org
Subject: Re: Downloading/Uploading RTEMS app to mcp750
mcp750 has a rom monitor that can load and execute an rtems image via tftp over ethernet- "nbo" command will do it. The output of the RTEMS compilation will be an executable, that the mcp750 can load from a tftp server. Very convenient. Once your app is in a more final state you can put it in the flash or on a hard disk and the rom monitor will load it from there- same exe format.
Greg
On 02/19/2014 11:28 AM, Noble N. Nkwocha wrote:
Hi Joel,
I do know that "RAD750 is ITARS" from your response to my earlier question several weeks ago. I am asking about mcp750. Is mcp750 ITARS too, or is it synonymous with RAD750?
Thank you,
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Wednesday, February 19, 2014 11:15 AM
To: Noble N. Nkwocha; rtems-users at rtems.org<mailto:rtems-users at rtems.org>
The RAD750 is ITARS and there is no public documentation on it.
My recollection is that we used the hardware debugger or downloaded
via SuROM in its expected format.
--joel
On 2/19/2014 9:56 AM, Noble N. Nkwocha wrote:
Hi everyone,
1. Is there a documented process for downloading / uploading an RTEMS .ralf / .exe image onto a PowerPC/mcp750 board?
2. If there is, would someone be kind enough to point us to it? Otherwise, could someone please help with how to?
Thank you,
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140219/ab9feedc/attachment.html>
