RAW UART
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 20 16:29:54 UTC 2014
On 2/20/2014 10:28 AM, Nicolás Alvarez wrote:
> Thanks Joel, finally we are using the console driver, setting the uart
> in non-canonical mode with termios. It´s working great.
A bunch of email was stuck in the outbox on my phone. :(
I am glad it is working now.
> Regards,
> *Ing. Nicolás Alvarez*
> cel: 03548-15638454
> http://ar.linkedin.com/in/ingalvarez/en
> On Thu, Feb 20, 2014 at 1:15 PM, Joel Sherrill
> <Joel.Sherrill at oarcorp.com <mailto:Joel.Sherrill at oarcorp.com>> wrote:
> If you do that, you won't get the driver at all. Your code is
> correct and just reopening the device and changing the settings.
> The issue is what to do with stdin, out, and err if you reuse the
> physical device.
> On Dec 23, 2013 12:46 PM, Wendell Silva <silvawp at gmail.com
> <mailto:silvawp at gmail.com>> wrote:
> To avoid the console driver to be initialized by the BSP, I
> guess it is sufficient to remove the
> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER from your "system.h".
> 2013/12/23 Nicolás Alvarez <nicoalar.22 at gmail.com
> <mailto:nicoalar.22 at gmail.com>>
> Hi all,
> I'm trying to use the raw uart driver interface, but it
> looks like that the bsp is initializing the console
> driver. How can I avoid this? I have read that someone use
> the console driver in "raw mode", is it the right way?
> Regards,
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20140220/872a17ae/attachment.html>
