SPARC Context Switch Code
Sebastian Huber
Thu Feb 6 11:33:42 UTC 2014
On 2014-02-06 12:17, Ingolf Steinbach wrote:
> My original reply (which was also sent to Sebastian directly) bounced
> from the list, so here we are again.
> 2014-02-06 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>> what do the RTEMS SPARC user think about the attached patch? Why did the
>> SPARC context switch code save and restore volatile registers?
> According to the SPARC ABI, volatility of a register means that there
> is no guarantee that the register will retain its state across a
> function call.
Yes.
> I understand that the _CPU_Context_switch can be
> invoked at arbitrary places within a user program (at least when using
> preemptive scheduling), so it must make sure that *all* registers are
> saved and restored. Otherwise it would render %g1 pretty much useless
> as (from a user POV) its content might change in an unpredictable way
> in the middle of a sequence of instructions.
Why do you think that _CPU_Context_switch() is invoked at arbitrary places?
The only valid invocation places for _CPU_Context_switch() are
_Thread_Dispatch() and _Thread_Start_multitasking().
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
