SPARC Context Switch Code
Gedare Bloom
gedare at rtems.org
Thu Feb 6 14:33:31 UTC 2014
On Thu, Feb 6, 2014 at 7:45 AM, Sebastian Huber
> On 2014-02-06 13:17, Ingolf Steinbach wrote:
>> 2014-02-06 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>> This switch
>> could happen at arbitrary places (in the interrupted task).
> Interrupts cannot happen at arbitrary places. Interrupts can happen when
> interrupts are enabled.
> The interrupt prologue and epilogue code must take care about the
> interrupted context. This is done usually in two steps. The first step is
> performed by the processor and the second step is some code that
> saves/restores the rest of the volatile context. This has nothing to do
> with the _CPU_Context_switch() function.
Sebastian is correct. The callee-save (volatile) registers are saved
by the ISR handler in case of an interrupt. This is a separate case
from the context switch code. In case of a dispatch from an ISR, the
return path from the dispatch (that resumes the interrupted thread)
will restore the volatile registers.
I think it is safe to remove those registers from the saved context
state during a context switch.
This issue and others involving context need to be revisited however
in case thread migrations are allowed. I believe (unverified) thread
migrations in the sparc can be complex due to the register windows and
size of the architected state.
-Gedare
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-users mailing list
> rtems-users at rtems.org
