Downloading/Uploading RTEMS app to mcp750
    Oyake, Amalaye (398K)
    amalaye.oyake at jpl.nasa.gov
    Wed Feb 19 16:49:30 UTC 2014
Hello Noble,
The MCP750 (the generic Motorola board that uses the PPC 750) should come with a bootloader. Connect it to a terminal program (Hyper Terminal is usually very straight forward), typically the settings are 9600-8-N-1 and then see what happens after a reset. Some of these boards have 1 or 2 serial ports, you just have to twiddle around to get the right one.
Once you get the boot-loader going, you will see whether it is a VxWorks bootloader or Uboot or something else. I think you can get RTEMS loaded using the VxWorks bootloader (never tried it, but it seems "reasonable")  ...
The procedure is the same for any board - You have to find the bootloader (Uboot, GRUB, LILO or whatever it may be).
The Stanford guys use some VME set up which should have similar procedures.
Regards,
* Amalaye Oyake                                    *
* Flight Software Applications & Data Product Mgmt */\
* 818.393.7168 work   626.399.1707 cell            *||
* Jet Propulsion Laboratory, Pasadena  CA 91109   */||\
________________________________
From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on behalf of Noble N. Nkwocha [Noble.N.Nkwocha at nasa.gov]
Sent: Wednesday, February 19, 2014 8:28 AM
To: Joel Sherrill; rtems-users at rtems.org
Subject: RE: Downloading/Uploading RTEMS app to mcp750
Hi Joel,
I do know that “RAD750 is ITARS” from your response to my earlier question  several weeks ago.    I am asking about mcp750.    Is mcp750 ITARS too, or is it synonymous with RAD750?
Thank you,
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
(505) 238-5927 Cellular (Evenings, Nights and Weekends ONLY)
Noble.N.Nkwocha at NASA.Gov<mailto:Noble.N.Nkwocha at nasa.gov>
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Wednesday, February 19, 2014 11:15 AM
To: Noble N. Nkwocha; rtems-users at rtems.org
Subject: Re: Downloading/Uploading RTEMS app to mcp750
The RAD750 is ITARS and there is no public documentation on it.
My recollection is that we used the hardware debugger or downloaded
via SuROM in its expected format.
--joel
On 2/19/2014 9:56 AM, Noble N. Nkwocha wrote:
Hi everyone,
1.       Is there a documented process for downloading / uploading an RTEMS .ralf / .exe image onto a PowerPC/mcp750 board?
2.       If there is, would someone be kind enough to point us to it?   Otherwise, could someone please help with how to?
Thank you,
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com>        On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20140219/6b76c95b/attachment-0001.html>
