"sparc-rtems4.10-sis.exe" is missing
Gedare Bloom
gedare at rtems.org
Mon Feb 24 20:36:56 UTC 2014
Hi Noble,
The manual for 4.10 says you should pass --enable-sim to the gdb configure:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/started/started00051.html
If that step was missed, you would not get the sis simulator in your gdb.
-Gedare
On Mon, Feb 24, 2014 at 3:35 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hi,
> I have /opt/rtems-4.11/bin/sparc-rtems4.11-sis
> Perhaps 4.10 does not package the sis directly.
> I see you have the sparc-gdb, so you can see if it has the sis
> simulator built-in by running:
> $> sparc-rtems4.10-gdb hello.exe
> $> tar sim
> $> load
> $> run
> And you should get back the hello world printout.
> -Gedare
> On Mon, Feb 24, 2014 at 1:03 PM, Noble N. Nkwocha
> <Noble.N.Nkwocha at nasa.gov> wrote:
>> Hi everyone,
>> We got a successful build of RTEMS 4.10 for the sparc/sis target processor
>> and BSP combinations. We also got some of the samples successfully built.
>> Now we just need to
>> be able to run them with "sis". Our "sparc-rtems4.10 tool chain" is
>> successfully built and installed.
>> I tried "sparc-rtems4.10-sis hello.exe" and got "sh: sparc-rtems4.10-sis:
>> command not found".
>> Q1: What is the path to: "sparc-rtems4.10-sis.exe"? Where is it located?
>> It is not in our "/opt/rtems-4.10/bin/" directory.
>> Here is a list of the sparc-rtems4.10 files in our "/opt/rtems-4.10/bin/"
>> directory:
>> sparc-rtems4.10-addr2line.exe
>> sparc-rtems4.10-ar.exe
>> sparc-rtems4.10-as.exe
>> sparc-rtems4.10-c++.exe
>> sparc-rtems4.10-c++filt.exe
>> sparc-rtems4.10-cpp.exe
>> sparc-rtems4.10-difftest
>> sparc-rtems4.10-g++.exe
>> sparc-rtems4.10-gcc-4.4.7.exe
>> sparc-rtems4.10-gcc.exe
>> sparc-rtems4.10-gccbug
>> sparc-rtems4.10-gcov.exe
>> sparc-rtems4.10-gdb.exe
>> sparc-rtems4.10-gprof.exe
>> sparc-rtems4.10-ld.exe
>> sparc-rtems4.10-nm.exe
>> sparc-rtems4.10-objcopy.exe
>> sparc-rtems4.10-objdump.exe
>> sparc-rtems4.10-ranlib.exe
>> sparc-rtems4.10-readelf.exe
>> sparc-rtems4.10-size.exe
>> sparc-rtems4.10-sorttimes
>> sparc-rtems4.10-strings.exe
>> sparc-rtems4.10-strip.exe
>> unhex.exe
>> Q2: Why are we missing "sparc-rtems4.10-sis.exe"?
>> Thank you,
>> Noble N. Nkwocha
>> (681) 753-5218 Work
>> (304) 816-3718 Home
>> (505) 238-5927 Cellular (Evenings, Nights and Weekends ONLY)
>> Noble.N.Nkwocha at NASA.Gov
>> From: Noble N. Nkwocha
>> Sent: Wednesday, February 19, 2014 11:56 AM
>> To: 'Greg Menke'; rtems-users at rtems.org
>> Subject: RE: Downloading/Uploading RTEMS app to mcp750
>> Thank you.
>> Noble N. Nkwocha
>> (681) 753-5218 Work
>> (304) 816-3718 Home
>> From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
>> On Behalf Of Greg Menke
>> Sent: Wednesday, February 19, 2014 11:52 AM
>> To: rtems-users at rtems.org
>> Subject: Re: Downloading/Uploading RTEMS app to mcp750
>> mcp750 has a rom monitor that can load and execute an rtems image via tftp
>> over ethernet- "nbo" command will do it. The output of the RTEMS
>> compilation will be an executable, that the mcp750 can load from a tftp
>> server. Very convenient. Once your app is in a more final state you can
>> put it in the flash or on a hard disk and the rom monitor will load it from
>> there- same exe format.
>> Greg
>> On 02/19/2014 11:28 AM, Noble N. Nkwocha wrote:
>> Hi Joel,
>> I do know that "RAD750 is ITARS" from your response to my earlier question
>> several weeks ago. I am asking about mcp750. Is mcp750 ITARS too, or
>> is it synonymous with RAD750?
>> Thank you,
>> Noble N. Nkwocha
>> (681) 753-5218 Work
>> (304) 816-3718 Home
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: Wednesday, February 19, 2014 11:15 AM
>> To: Noble N. Nkwocha; rtems-users at rtems.org
>> The RAD750 is ITARS and there is no public documentation on it.
>> My recollection is that we used the hardware debugger or downloaded
>> via SuROM in its expected format.
>> --joel
>> On 2/19/2014 9:56 AM, Noble N. Nkwocha wrote:
>> Hi everyone,
>> 1. Is there a documented process for downloading / uploading an RTEMS
>> .ralf / .exe image onto a PowerPC/mcp750 board?
>> 2. If there is, would someone be kind enough to point us to it?
>> Otherwise, could someone please help with how to?
>> Thank you,
>> Noble N. Nkwocha
>> (681) 753-5218 Work
>> (304) 816-3718 Home
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
