problems with RFS filesystem and mkdir
Phil Smith philip.smith.ucl at gmail.com
Thu Jan 2 21:54:06 UTC 2014
On Thu, Jan 02, 2014 at 07:53:40PM +0000, Cudmore, Alan P. (GSFC-5820) wrote:
> This example fails on my 4.10.2 sparc/sis BSP as well. I don't have a 4.11
> BSP set up right now, but I can try that later.
> If I replace rtems_mkdir with mkdir and remove the trailing "/" from the
> directory names, it works. This is what our application uses, so that may
> be why I have not seen this problem.
> I have also confirmed that the example does not fail on IMFS ( if you skip
> mounting the nvram/RFS disk )
> It does seem like a bug to me.
Thanks for the confirmation and the tip.
Philip J. Smith
Mullard Space Science Laboratory,
Dept. of Space and Climate Physics,
University College London.
