Flashdisk failing at rtems_fdisk_compact() - shouldn't I get a device node regardless?
Fri Jan 10 14:04:02 UTC 2014
On 01/10/2014 06:17 AM, Nick Withers wrote:
> Hey all,
> I'm playing with Flashdisk again, with the hope of using JFFS2 on top of
> it.
> At the moment I can't get the device node to even appear because
> rtems_fdisk_initialize() is failing in rtems_fdisk_compact() ("nothing
> to recycle" [1]).
Using JFFS2 on top of a flash disk makes no sense.  I would only use the
low-level flash driver (rtems_fdisk_driver_handlers).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
