no acceptable C compiler found in $PATH : configure error in fedora 20
Tom Smith
venture.g at gmail.com
Tue Jan 14 13:25:46 UTC 2014
Hi everyone !
os: fedora 20
toolchain: arm-rtems4.11 I installed the toolchain according to
http://rtems.org/wiki/index.php/APT/Yum_Repository.
command line: ../rtems/configure --target=arm-rtems4.11
--enable-rtemsbsp=csb337 --enable-networking
error msg:
checking for i686-pc-linux-gnu-gcc... no
checking for gcc... no
checking for i686-pc-linux-gnu-cc... no
checking for cc... no
checking for i686-pc-linux-gnu-cl.exe... no
checking for cl.exe... no
configure: error: in `/home/rtems/studio/build/tools/build':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
PATH :
/opt/rtems-4.11/bin/:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/rtems/.local/bin:/home/rtems/bin
Is there anything I can do to fix this error ? thanks!
URL: <http://lists.rtems.org/pipermail/users/attachments/20140114/f963bdcc/attachment.html>
