rtems-users Digest, Vol 88, Issue 10
Nick Withers nick.withers at anu.edu.au
Wed Jan 15 06:19:01 UTC 2014
Hi Tom,
Could you reply to the list, please? There'll be others who can provide
more insight that I :-)
On Wed, 2014-01-15 at 12:42 +0800, Tom Smith wrote:
> I checked the latest online docs,
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/Using-the-RTEMS-configure-Script-Directly.html
> it also asks me to find the
> tools/rtems-4.11.<VERSION>/README.configure in the RTEMS source tree.
Ah, sorry about that.
Looking at the directories directly
under /home/nick/rtems/git/rtems/c/src/lib/libbsp/arm might do it? Think
you've found that, though...
> I have a beaglebone black, whose cpu is am3359, a cortex a8 cpu.
> Realview_pbx may be a good start point,  which has a cortex a9 cpu.
> Is there anything special I should keep in mind when I do the bsp
> migration ?
I've never done that I'm afraid, so don't have anything to suggest.
Good luck!
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
> 2014/1/15 Nick Withers <nick.withers at anu.edu.au>
>         On Wed, 2014-01-15 at 08:43 +0800, Tom Smith wrote:
>         > Hi huber
>         > Can you give me a hint  why I should get a native c
>         compiler ?   I am
>         > just building for arm architecture.
>         Right, but you don't have a C compiler, so you can't build
>         anything for
>         your host that requires a C compiler.
>         "sudo yum install gcc" perhaps?
>         > And  I am wondering  what should be specified after
>         > `--enable-rtemsbsp=',  I read the online doc page,
>         http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.1/share/rtems/html/started/started00062.html
>         >  but I can't find the README.configure file.
>         That's for an older version of RTEMS than you're trying to
>         build (which
>         is apparently 4.11, from an earlier email from you).
>         Have you seen
>         http://www.rtems.org/wiki/index.php/Quick_Start ?
>         > So what is the available bsp names ?
>         I don't personally know, I'm afraid. Do you actually have
>         hardware
>         you're building for? Are you wanting to run in a simulator?
>         > thanks
>         Nick Withers
