Flashdisk failing at rtems_fdisk_compact() - shouldn't I get a device node regardless?
Wed Jan 15 07:24:56 UTC 2014
On 2014-01-15 03:08, Nick Withers wrote:
>>>> I would only use the
>>>> > >>low-level flash driver (rtems_fdisk_driver_handlers).
>>> > >Cheers - I'll have a gander at that.
>> >If this works out, and I see no reason for it not to, it might be a good
>> >idea to move these handlers and the interface into something different
>> >to avoid confusion.
> It turns out that the libchip am29lv160 stuff ain't for me, as my BSP
> (MVME3100) has two of them in parallel (which changes their interface).
> This'd explain the dramas I was having with the Flashdisk driver earlier
> (http://www.rtems.org/pipermail/rtems-users/2013-August/011806.html  ),
> too.
> Luckily, and once again, Till's been here before so there's
> libbsp/powerpc/shared/flash/spansionFlash.c.
> So I've knocked up a wrapper around it for JFFS2. I can't spot anything
> obviously wrong with it, but am encountering an error when writing a
> file to a newly formatted FS that seems to be fairly common - "Node
> totlen on flash (0xFFFFFFFF) != totlen from node ref (0x00000044)" (the
> whole struct jffs2_unknown_node's all-1s).
> Solutions suggested through good ol' Google seem to be related to the
> type of flash in use / Linux-specifics / big-file-relative-to-FS (this
> isn't), etc.; Nothing that would seem to apply here...?
> ____
> [/] # ls -l/etc/daq/
> total 0
> -rw-r--r--  1 root  root   68 Jan 15 01:43 crate
> -rw-r--r--  1 root  root  141 Jan 15 01:43 daq
> drwxr-xr-x  1 root  root    0 Jan  1  1970 nv
> [/] # ls -l /etc/daq/nv
> [/] # cp /etc/daq/daq /etc/daq/nv/daq
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 12 B to 0xf80000
> ERASING DONE
Who prints this "ERASING DONE"?
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 68 B to 0xf8000c
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 40 B to 0xf80050
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 4 B to 0xf80078
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 68 B to 0xf8007c
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 12 B to 0xf8000c
> ERASING DONE
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 68 B to 0xf800c0
> [DEBUG] mvme3100_flash.c:305: mvme3100_flash_device_write(): 144 B to 0xf80104
> Node totlen on flash (0xFFFFFFFF) != totlen from node ref (0x00000044)
I would make sure that the callback functions do what they are supposed to do.
  For me this looks like a problem with the flash driver routines.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
