RTEMS Installation & Configuration
Oyake, Amalaye (398K)
amalaye.oyake at jpl.nasa.gov
Wed Jan 15 18:28:06 UTC 2014
Hello Noble,
When you build an application, the kernel (library) gets linked in. Look at the source code for the Hello World example as start.
Many of us are VxWorksified in our thinking, where the Kernel is active and expects you to dynamically load the object files. RTEMS is different.
Regards,
* Amalaye Oyake *
* Instrument Product Software Development Group */\ *
* Jet Propulsion Laboratory, Pasadena *|| *
* CA 91109 818.393.7168 work 626.399.1707 cell /||\ *
From: "Noble N. Nkwocha" <Noble.N.Nkwocha at nasa.gov<mailto:Noble.N.Nkwocha at nasa.gov>>
Date: Wednesday, January 15, 2014 8:13 AM
To: "rtems-users at rtems.org<mailto:rtems-users at rtems.org>" <rtems-users at rtems.org<mailto:rtems-users at rtems.org>>
Subject: RTEMS Installation & Configuration
Hi everyone,
My name is Noble N. Nkwocha and I am new to and with RTEMS.
I was successful “I believe”, in installing and Configuring RTEMS 4.10.2 for the i386 and PowerPC target processors. I used the pre-built tools and binary versions. Would someone please help with the following questions?
1. Where is the resulting RTEMS Kernel after a successful configuration? What is its filename? Should I expect to have a file named “i386-rtems4.10-run” and another one named “powerpc-rtems4.10-run” after the successful build of RTEMS4.10.2?
2. Why is it that I cannot not get a successful RTEMS configuration for “powerpc” and “rad750” as target and BSP options respectively? I get an error message indicating that a branch for the BSP (rad750) was not found. The same problem occurs when I try “qemuprep” for a “powerpc” BSP. The RTEMS Documentations I have, state that both the “rad750” and “qemuprep” are included in the standard RTEMS PowerPC BSPs distribution. What am I not doing correct, here?
3. Why do I get the System Error message below, each time I try the following:
$i386-rtems4.10-gdb `find . -name ticker.exe`
[cid:image003.png at 01CF11E2.C6AA62D0]
This the command I used for my configurations. “powerpc” and “psim” were substituted for the target and BSP for our successful PowerPC configuration
../rtems-4.10.2/configure --target=i386-rtems4.10 --enable-rtemsbsp=i386ex --enable-cxx --enable-tests=samples
make all
make install
Thank you,
Noble N. Nkwocha
(681) 753-5218 Work
(304) 816-3718 Home
(505) 238-5927 Cellular (Evenings, Nights and Weekends ONLY)
Noble.N.Nkwocha at NASA.Gov<mailto:Noble.N.Nkwocha at nasa.gov>
From: rtems-users-bounces at rtems.org<mailto:rtems-users-bounces at rtems.org> [mailto:rtems-users-bounces at rtems.org] On Behalf Of Joel Sherrill
Sent: Monday, January 06, 2014 12:24 PM
To: John Harwell; rtems-users at rtems.org<mailto:rtems-users at rtems.org>
Subject: Re: RTEMS Posix lock failure
On 1/6/2014 10:58 AM, John Harwell wrote:
Hello,
When RTEMS entries the Internal_error_Occurred() routine, it is within the context of an ISR, according to the value of _ISR_Nest_level.
After reading the documentation on rtems_fire_after() here<http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicTimer.html#gad9785a6bd78ab5a591a134d147b2bdd3>, I realized that because my function attempts to acquire a global
mutex lock within an ISR context, RTEMS will correctly lockup. Now that I know the cause, restructuring my code should be
relatively simple.
You could use the timer server version of the calls but acquiring a lock potentially could
potentially negatively impact other timers managed by the server.
Thanks for your help,
John Harwell
Engineer
High Reliability Software Section
Communications and Embedded Systems Department
john.harwell at swri.org<mailto:john.harwell at swri.org>
Office: 210-522-5965
Southwest Research Institute (SwRI)
6220 Culebra Road, San Antonio, TX 78238-5166
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20140115/26b646db/attachment.html>
Type: image/png
Desc: image003.png
URL: <http://lists.rtems.org/pipermail/users/attachments/20140115/26b646db/attachment.png>
