MVME5500 1 Gbit Ethernet no longer works
Till Straumann strauman at slac.stanford.edu
Thu Jan 16 22:55:21 UTC 2014
We almost exclusively use 6100s at this point. I used 5500s mainly for
testing.
The BSP is certainly better tested on the 6100 although most code
(except for
the NIC drivers) is the same (which is why the BSP is run-time
compatible with
both boards).
- T.
On 01/16/2014 02:21 PM, Peter Dufault wrote:
> Till, does SLAC use a mixture of 5500 and 6100 painlessly with Beatnik?  I've told my client that uses the MVME5500 with Beatnik to get a 6100 in-house and test it out with their RTEMS software.  As long as things are changing on the MVME5500 (slower cache, different ethernet controller) they should evaluate using the 6100 instead (faster processor, two gig-E ethernets, etc) to see if that can be used on new systems and as a replacement part (with the replacement maybe tied to recent software releases, they can hoard the older boards for really old systems).
> On Jan 16, 2014, at 12:04 , Till Straumann <strauman at slac.stanford.edu> wrote:
>> FWIW: the driver I ported for the beatnik BSP is almost 10 years old
>> and it seems to support the 82545GM (IDs 0x1026, 0x1027, 0x1028).
>> You could use this BSP or you could also use the driver from the
>> libbsdport addon package (which is newer than the one in beatnik).
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
