Interested in contribute to RTEMS
Wed Jan 22 17:42:26 UTC 2014
I think you should also have gotten *.exe files for that target? What
version of RTEMS are you using?
The instructions at http://wiki.rtems.org/wiki/index.php/Qemu describe
how to use Qemu with RTEMS especially on the i386. That is a good
simulator to use and work with, as it also works for a lot of other
RTEMS targets.
-G
On Wed, Jan 22, 2014 at 12:07 PM, Garvit Sharma <garvits45 at gmail.com> wrote:
> Hi, I have done with the following tasks :
> 1. Installed GNU cross-compilation tools for RTEMS on my host system.
> 2. Installed RTEMS OS for the target host.
> 3. I have chosen the target as i386 and BSP as i386/pc686.
> 4. I have build the examples and from that I got *.ralf files. I know these
> files are executables which are to be run on target machine. But how to do
> so ? Is not there any simulator for that ?
> Thanks,
> On Wed, Jan 22, 2014 at 9:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Probably the easiest place to start is
>> http://www.rtems.org/wiki/index.php/GSoC_Getting_Started
>> You may like to build the tools using the RSB:
>> http://www.rtems.org/wiki/index.php/RSB
>> -Gedare
>> On Wed, Jan 22, 2014 at 6:16 AM, Garvit Sharma <garvits45 at gmail.com>
>> wrote:
>> > Hi, I have installed cross-compiler toolsets and now it is the time to
>> > build
>> > rtems from the source. I want to know that for which target architecture
>> > should I build rtems.
>> > On Wed, Jan 22, 2014 at 11:50 AM, Nick Withers <nick.withers at anu.edu.au>
>> > wrote:
>> >> On Wed, 2014-01-22 at 11:41 +0530, Garvit Sharma wrote:
>> >> > Hello All,
>> >> > I am a newbie to the world of rtems and want to make contributions
>> >> > towards rtems. I have experience with
>> >> > C/SystemProgramming/DeviceDrivers and gnu tools like gdb, strace and
>> >> > Oprofile. Please show me the direction to start from.
>> >> Hi Garvit!
>> >> (Humble user here)
>> >> Glad to hear you want to contribute, that's awesome :-)
>> >> Perhaps have a look at
>> >> http://www.rtems.org/wiki/index.php/Contributing#How_can_I_help.3F ?
>> >> It's got both coding and non-coding suggestions that might help.
>> >> Looking forward to your contributions :-)
>> >> Nick Withers
>> >> Embedded Systems Programmer
>> >> Department of Nuclear Physics, Research School of Physics and
>> >> Engineering
>> >> The Australian National University (CRICOS: 00120C)
>> >> > Thanks,
>> >> > Garvit Sharma
>> >> > B.Tech | Computer Science and Engineering
>> >> > UG Final year
>> >> > LNM IIT, Jaipur
>> >> > No Body is a Scholar by birth, its only hard work and strong
>> >> > determination that makes him master.
>> >> > _______________________________________________
>> >> > rtems-users mailing list
>> >> > rtems-users at rtems.org
>> >> > http://www.rtems.org/mailman/listinfo/rtems-users
>> > Garvit Sharma
>> > UG Final year
>> > LNM IIT, Jaipur
>> > determination
> Garvit Sharma
> UG Final year
> LNM IIT, Jaipur
> No Body is a Scholar by birth, its only hard work and strong determination
