Interested in contribute to RTEMS
Wed Jan 22 18:16:24 UTC 2014
You might like to consider going to the task list for Google Code-In
[1] and filter for "RTEMS" as the Organization field and "open" for
the Status field. These tasks are relatively easy to get started on so
you can look for something that might interest you. There are some
possible bug fixes and some test case refactoring tasks.
[1] http://www.google-melange.com/gci/tasks/google/gci2013
On Wed, Jan 22, 2014 at 1:03 PM, Garvit Sharma <garvits45 at gmail.com> wrote:
> I am configuring qemu to see examples working, In the meanwhile please tell
> me how should I make my first contribution to this organization. Which bug
> should I start with ?
> On Wed, Jan 22, 2014 at 11:21 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> ok. for 4.10 i think it should "just work". For new development, we
>> suggest using 4.11 (the current git master). We only accept bug fixes
>> submitted to 4.10. Hopefully a 4.11 release will come soon!
>> -Gedare
>> On Wed, Jan 22, 2014 at 12:45 PM, Garvit Sharma <garvits45 at gmail.com>
>> wrote:
>> > yes, I have got *.exe files, also *.ralf. I am using rtems4.10. I am
>> > using
>> > fedora-19.
>> > On Wed, Jan 22, 2014 at 11:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> I think you should also have gotten *.exe files for that target? What
>> >> version of RTEMS are you using?
>> >> The instructions at http://wiki.rtems.org/wiki/index.php/Qemu describe
>> >> how to use Qemu with RTEMS especially on the i386. That is a good
>> >> simulator to use and work with, as it also works for a lot of other
>> >> RTEMS targets.
>> >> -G
>> >> On Wed, Jan 22, 2014 at 12:07 PM, Garvit Sharma <garvits45 at gmail.com>
>> >> wrote:
>> >> > Hi, I have done with the following tasks :
>> >> > 1. Installed GNU cross-compilation tools for RTEMS on my host system.
>> >> > 2. Installed RTEMS OS for the target host.
>> >> > 3. I have chosen the target as i386 and BSP as i386/pc686.
>> >> > 4. I have build the examples and from that I got *.ralf files. I know
>> >> > these
>> >> > files are executables which are to be run on target machine. But how
>> >> > to
>> >> > do
>> >> > so ? Is not there any simulator for that ?
>> >> > Thanks,
>> >> > On Wed, Jan 22, 2014 at 9:00 PM, Gedare Bloom <gedare at rtems.org>
>> >> > wrote:
>> >> >> Probably the easiest place to start is
>> >> >> http://www.rtems.org/wiki/index.php/GSoC_Getting_Started
>> >> >> You may like to build the tools using the RSB:
>> >> >> http://www.rtems.org/wiki/index.php/RSB
>> >> >> -Gedare
>> >> >> On Wed, Jan 22, 2014 at 6:16 AM, Garvit Sharma <garvits45 at gmail.com>
>> >> >> wrote:
>> >> >> > Hi, I have installed cross-compiler toolsets and now it is the
>> >> >> > time
>> >> >> > to
>> >> >> > build
>> >> >> > rtems from the source. I want to know that for which target
>> >> >> > architecture
>> >> >> > should I build rtems.
>> >> >> > On Wed, Jan 22, 2014 at 11:50 AM, Nick Withers
>> >> >> > <nick.withers at anu.edu.au>
>> >> >> > wrote:
>> >> >> >> On Wed, 2014-01-22 at 11:41 +0530, Garvit Sharma wrote:
>> >> >> >> > Hello All,
>> >> >> >> > I am a newbie to the world of rtems and want to make
>> >> >> >> > contributions
>> >> >> >> > towards rtems. I have experience with
>> >> >> >> > C/SystemProgramming/DeviceDrivers and gnu tools like gdb,
>> >> >> >> > strace
>> >> >> >> > and
>> >> >> >> > Oprofile. Please show me the direction to start from.
>> >> >> >> Hi Garvit!
>> >> >> >> (Humble user here)
>> >> >> >> Glad to hear you want to contribute, that's awesome :-)
>> >> >> >> Perhaps have a look at
>> >> >> >> http://www.rtems.org/wiki/index.php/Contributing#How_can_I_help.3F ?
>> >> >> >> It's got both coding and non-coding suggestions that might help.
>> >> >> >> Looking forward to your contributions :-)
>> >> >> >> Nick Withers
>> >> >> >> Embedded Systems Programmer
>> >> >> >> Department of Nuclear Physics, Research School of Physics and
>> >> >> >> Engineering
>> >> >> >> The Australian National University (CRICOS: 00120C)
>> >> >> >> > Thanks,
>> >> >> >> > Garvit Sharma
>> >> >> >> > B.Tech | Computer Science and Engineering
>> >> >> >> > UG Final year
>> >> >> >> > LNM IIT, Jaipur
>> >> >> >> > No Body is a Scholar by birth, its only hard work and strong
>> >> >> >> > determination that makes him master.
>> >> >> >> > _______________________________________________
>> >> >> >> > rtems-users mailing list
>> >> >> >> > rtems-users at rtems.org
>> >> >> >> > http://www.rtems.org/mailman/listinfo/rtems-users
>> >> >> > Garvit Sharma
>> >> >> > UG Final year
>> >> >> > LNM IIT, Jaipur
>> >> >> > determination
>> >> > Garvit Sharma
>> >> > UG Final year
>> >> > LNM IIT, Jaipur
>> >> > determination
>> > Garvit Sharma
>> > UG Final year
>> > LNM IIT, Jaipur
>> > determination
> Garvit Sharma
> UG Final year
> LNM IIT, Jaipur
> No Body is a Scholar by birth, its only hard work and strong determination
