Including 3rd party library headers?
Andrei Chichak groups at chichak.ca
Wed Jan 29 04:01:18 UTC 2014
I believe what Sebastian is referring to is the environment that you are using for your compiles. In my case, I am using a Mac and Eclipse, I set <C/C++ Build><Settings><Tool Settings><RTEMS C Compiler><Preprocessor><Include Paths (-I)>.
Your milage will vary, but if you tell us what you are driving, there may be someone here that can help.
Andrei
On 2014-January-28, at 2:11 PM, James Fitzsimons <james.fitzsimons at gmail.com> wrote:
> Hi Sebastian,
> Thanks for your reply.
> Ideally I was hoping to us the -I option to specify the header file location, I just can't quite figure out where to add that into the RTEMS makefile structure. Looking at the make/README I can see a good example of how to link in other libraries using LD_LIBS, but there's nothing about including other header files.
> Apologies if I am missing something obvious!
