Including 3rd party library headers?
James Fitzsimons
james.fitzsimons at gmail.com
Thu Jan 30 00:38:18 UTC 2014
Thanks very much guys,
I'm thought I'd tried CFLAGS, but I obviously didn't have something quite
right so I'll give it another shot.
I'll definitely look into Eclipse - I've used it before for C/C++ stuff and
found it excellent. I'm trying to start out pretty vanilla with RTEMS just
so I get a really good handle on how the whole build process works (there
are a LOT of makefiles to understand) as I've found with other tools that
an IDE can often make things nice and easy until it goes wrong, and if you
don't understand what it's doing under the hood you are all of a sudden in
very deep water.
Cheers!
James
On 30 January 2014 12:53, Simon Williams <williamssimonp at gmail.com> wrote:
> Ah, -I and CFLAGS it is then. That'll teach me to read posts properly and
> not just skim them! :-)
> I started using Eclipse for Java, but I moved to using Netbeans as I
> prefer it, but Eclipse with CDT is a grest C/C++ IDE and the RTEMS plug in
> makes RTEMS development more productive than vi. I don't really know of an
> alternative iif you want an IDE for RTEMS, but that may be just because
> I've not looked.
> Regards
> Simon
> On 29 Jan 2014 23:36, "Nick Withers" <nick.withers at anu.edu.au> wrote:
>> On Wed, 2014-01-29 at 23:31 +0000, Simon Williams wrote:
>> > Wouldn't thst be -L for the lbrary path? The -l option is usef to
>> > specify a library.
>> > Also, linker flags are usually in LDFLAGS, CFLAGS is for compiler
>> > flags. It does of course depend on your Makefile.
>> It's include paths he's after, which are for the compiler.
>> > I would recommend Eclipse. It won't do everything for you, but it can
>> > help by pointing the way!
>> I've heard a lot of good things about Eclipse. I've got a personal peeve
>> against Java and that's really all that's kept me from trying it!
>> > Regards
>> > Simon
>> > On 29 Jan 2014 22:18, "Nick Withers" <nick.withers at anu.edu.au> wrote:
>> > On Wed, 2014-01-29 at 22:29 +1300, James Fitzsimons wrote:
>> > > Thanks Andrei,
>> > > I'm using a very plain vanilla environment at the moment.
>> > Ubuntu 13.10
>> > > with tool chain built using rtems source builder.
>> > > I'm using the template makefile for my test application, and
>> > am just
>> > > running make directly from bash.
>> > > No IDE or fancy build environment yet!
>> > I'd've said the RTEMS'provided Makefiles (there are a number
>> > of them,
>> > chained together) are pretty fancy... But then, I have trouble
>> > with just
>> > one Makefile :-P
>> > Anyway, try:
>> > CFLAGS+=-I/bam/headers
>> > > Cheers,
>> > > James
>> > > On 29 January 2014 17:01, Andrei Chichak <groups at chichak.ca>
>> > wrote:
>> > > I believe what Sebastian is referring to is the
>> > environment
>> > > that you are using for your compiles. In my case, I
>> > am using a
>> > > Mac and Eclipse, I set <C/C++ Build><Settings><Tool
>> > > Settings><RTEMS C Compiler><Preprocessor><Include
>> > Paths (-I)>.
>> > > Your milage will vary, but if you tell us what you
>> > are
>> > > driving, there may be someone here that can help.
>> > > Andrei
>> > > On 2014-January-28, at 2:11 PM, James Fitzsimons
>> > > <james.fitzsimons at gmail.com> wrote:
>> > > > Hi Sebastian,
>> > > > Thanks for your reply.
>> > > > Ideally I was hoping to us the -I option to
>> > specify the
>> > > header file location, I just can't quite figure out
>> > where to
>> > > add that into the RTEMS makefile structure. Looking
>> > at the
>> > > make/README I can see a good example of how to link
>> > in other
>> > > libraries using LD_LIBS, but there's nothing about
>> > including
>> > > other header files.
>> > > > Apologies if I am missing something obvious!
>> Nick Withers
>> Embedded Systems Programmer
>> Department of Nuclear Physics, Research School of Physics and Engineering
>> The Australian National University (CRICOS: 00120C)
URL: <http://lists.rtems.org/pipermail/users/attachments/20140130/f9dbb960/attachment.html>
