cpuuse
Chris Johns
chrisj at rtems.org
Sun Jan 5 20:56:05 UTC 2014
On 6/01/2014 7:24 am, Claus, Ric wrote:
> Sometimes I see 'cpuuse' give results like the following:
> [/] cpuuse
> CPU USAGE BY THREAD
> ID | NAME | SECONDS | PERCENT
> 0x09010001 | IDLE | 33.568522 | 192.351
> 0x0a010001 | tcpI |4294966091.3351480 |4294960389.4294966833
> 0x0a010002 | Xinp | 1187.924336 |6800.972
> 0x0a010003 | CSHL | 0.057157 | 0.327
> 0x0b010001 | | 0.000000 | 0.000
> 0x0b010002 | | 0.000078 | 0.000
> 0x0b010003 | | 0.000265 | 0.001
> 0x0b010004 | | 0.054508 | 0.311
> TIME SINCE LAST CPU USAGE RESET IN SECONDS: 17.501697
I have seen the same thing on the zynq in the past.
> These things can happen in combination or individually:
> - the numbers in the seconds column are either individually greater than the time since last reset
> - the numbers in the seconds column sum up to be greater than the time since last reset
> - one or more of the numbers in the percent column is greater than 100
> - the sum of the numbers in the percent column is greater than 100
> I think, but am not sure, that these nonsensical results show up when either CPU usage by a task other than IDLE is ~100%, and/or the interrupt rate is high. In the above case I was sending UDP packets to the RTEMS system (with the LWIP network stack instead of the standard one) at almost, but not quite, the maximum rate.
> The RTEMS version is from a recent HEAD and the platform is a xilinx-zynq board.
How recent ? I fixed the capture engine testing it on the zynq and got
good results. I have just run the cpuuse command with a few telnet
sessions running 'ls -lsaR /net' of a large NFS share to make some load
and I am seeing no issues. Before I would. The capture engine's ctload
says I am running with a 50% load.
> The nameless threads are pthreads whereas the named threads are normal RTEMS tasks.
> Anyone have any idea about this or how to go about fixing it?
I suggest you update to the latest code and try again, plus I suggest
you try the capture engine's ctload command. With the traces I am seeing
nanosecond time stamping. I am running with no extra RTEMS patches these
days.
Note, I have added weak function support for MMU tables residing in the
application code.
